The way it works... a heater at the bottom heats the water causing it to be pushed up a tube and out over the coffee.
If the drip is very hot water, the heater is working.
What else can be wrong???
a plugged tube
If it does not leak when off, then you have a hole in that tube
Testimonial: "when I power it on it leaks water out where the tank resvior is when heatin and brewing little water drips comes out"
SOURCE: slow water drip
First of all it depends on the hardness of the water. Vinegar doesn't really work in the heavy lime belt area of the midwest. It is better if you use lime away. It is an ecolab product that is great at lime removal. Use one cup per pot. Then rinse two pots worth if this is the kind of machine that uses the same water that is put in during each brew cycle. Some brewers have a reservoir. Bunnomatic is an example of that kind of brewer. If you use lime away in that kind of brewer you need to run about thirty pots to remove all the lime scale remover from the brewer. Slow brewing can also be caused by over softened water. I drove from Indy to Iowa after installing a brewer and then a day later the store put in a softener and over softened the water causing the coffee filter to clog up with sodium. Also check the sprayer disc or head where the water comes out. Over time coffee "paste" will build up around the outlet and if you don't wipe it clean or "smear" the coffee grounds around the outlet that will slow down the brewing cycle. I have thirty years as a brewer technician and it is usually one of the things I have covered, providing that the heat element isn't defective.
SOURCE: My Cuisinart 10 cup Grind & Brew does not
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
SOURCE: Water goes directly to drip tray instead of to the brewing head.
Have the same issue with mine. Descaled it all and wouldn't even brew with no coffee OR filter in the housing, so I took it in to get it checked out. Turns out it's the solenoid valve that needs replacing. ~$60 part plus $90 labor, so I've decided to try and find that part and DIY, if I can. I'll let you know how that turns out!
SOURCE: water dripping slowly
You can get urnex at most reputable kitchen shoppes or order it. it will do a great job or you can run vinegar through the machine... be aware that it will smell horrible and will nedd to have at least 2 or 3 cycles of water ran afterwards but brewing this cycle a couple of times will bust up the lime. Doing it every month or so afterwards will keep it from coming up again. That would be my first step... hope that helps!
SOURCE: The water no longer shoots out. Now it slowly
run white vinegar or CLR thru it, see if it is just clogged up, if not then the heating coils are bad, just toss it
