Question about Dirt Devil Vacuums
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
SOURCE: Oreck Electrikbroom (battery) won't hold charge and pick up dirt.
Battery needs to be replaced. All rechargeable batteries have limited recharge cycles. NiCad's are usually used in these and also develop "memory' which keeps them from recharging fully.
Contact Oreck or reputable dealer for replacement.
Posted on Nov 16, 2008
SOURCE: roomba 4108 does not charge
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
Posted on Jan 10, 2009
SOURCE: Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Jan 24, 2009
SOURCE: i cant get the power brush to work
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Posted on Apr 08, 2009
Feb 11, 2018 | Dirt Devil Vacuums
Feb 18, 2016 | Dirt Devil Bd10025w Vacuum Cleaners
Jun 07, 2015 | Dirt Devil BD20020 Power Sweep Vacuum 72...
Oct 04, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Dec 07, 2011 | Dirt Devil Kone Vacuum- Blue Vacuum
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
Sep 18, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Jun 24, 2008 | Dirt Devil KONE Hand Vacuum MO213BLU...
428 people viewed this question
