Question about Power Computers & Internet
Vivitek Qumi Q5-RD turns off after a few seconds.
When I plug in the qumi and press the power button it makes two beeps and then the lamp turns on and displays the qumi logo. After that the lamp and the button lights turn off, but the fan is still running and blowing air. There are no blinking lights.
  • Power Master
  • 5,611 Answers
IS THIS A COMPUTER?
No it is a
Vivitek Qumi Q5-RD review A portable but robust projector did you read the manual on this projector, No 2 projectors made work the same nor diagnose same or same error codes
thus the magic manual for that topic.
we use google to find manuals using clear english questions.
like
Vivitek Qumi Q5-RD manual. first hit google finds it, amazing no?
and is 7 years old now, 2013
page 48 is the only error pages..
blink codes. temp lamp blue binks is overhtemp]
did you clean the projector this old first all lint in all vents and inside, every drop of lint blown out? this is 1st on all things made that get hot. Computers and that. thing .
q5 series.
https://www.manualslib.com/manual/1140891/Qumi-Q5.html?page=48&term=error&selected=1
are not free manuals , not amazing, ?
or get the thing serviced in shop, not get electrocuted or burned.
respect both and win.
Posted on Dec 15, 2019
4 Suggested Answers
6ya staff
SOURCE:
RedZone133
Robin Wilson
  • 25 Answers
SOURCE: lamp will not come on. Press power button, fan
You might not be getting power from the ballast, it may be gone.The ballast is what gives the lamp it's major charge of high power.
Posted on Oct 27, 2009
Kristoffer Martin
  • 293 Answers
SOURCE: Projector auto shut down
The blink pattern indicates the LED emitter is overheating.
Posted on Sep 08, 2014
Kristoffer Martin
  • 293 Answers
SOURCE: I have a vivitek qumi q2. It runs for about one
The blink pattern does indicate that it is overheating. You can find the user manual for this device via a google search. The troubleshoot codes are on page 37.
Sep 08, 2014 | Vivitek QUMI Q2 720p LED Projector QUMI-B
I have a vivitek qumi q2. It runs for about one minute and the turns off followed by a series of blinking lights on top, 3 blinks, pause, two blinks. It is getting warm so I think it may be a fan problem,...
Sep 08, 2014 | Televison & Video
I have a vivitek qumi q2 that runs for about a
The blink code indicates overheating. I suggest cleaning it.
How can I stop my Qumi Q5 shutting down after a minute?
It is most probably overheating. First you need to open up the unit and see if the fan moter is frozen. It is probably because you can't hear it spinning. There are usually two bushings one in the front and one at the rear of the motor. They are usually permentally lubricated but as we know nothing is forever. So, try to take some good quality oil like 3 in 1 and try to drip a drop on either side of the motor where the shaft comes out and then try spinning it by hand. Hopefully that may work but if not then as a last resort try spraying just a very small amount of WD-40 and try spinning it again. If it then does work then use the 3 in 1 again. WD-40 will probably clean the gum out of those bushings but it is not a proper lubricant so that is why you need to use that 3 in one or any good quality lubricant like gun oil.
If all else fails then you probably have a bad fan motor and it will have to be replaced. Just so you know I have had this same problem, usually with air conditioning fan motors and most of the time the lubrication method that I just described worked very well.
Good luck,
Marty
Jul 20, 2014 | Vivitek Qumi Q5 Super Bright HD Pocket...
Vivitek Qumi Q2 reset ?
Unplug the power cord from projector
--> HOLD down (keep holding down) the right key on the keypad (top of the projector) and Insert the power cord back to the projector
--> The "Power" and "Ready" LED light should blink TWICE and unplug the cord from the projector (while still holding down the right key)
from facebook site
Jan 02, 2013 | Vivitek Qumi Q2 WXGA 3D Ready LED Pocket...
Source not found I am using an Acer Aspire One
Make sure you are using ports other than the USB port. Vivitek Service indicates that at least some of their projectors do not use the USB port for input. "The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service
Hope this helps.
May 16, 2011 | Vivitek D825MS Projector
Have replaced projector bulb,can not reset lamptimer
turn the tv ON: On the side of the TV press the menu and volume up buttons at the same time for three seconds. The 'reset lamp timer?' will appear on the screen. Press the OK button to accept. You're done!
Oct 22, 2009 | Vivitek Televison & Video
Replace lamp on dlp tv
Jan 05, 2009 | Televison & Video
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Computers & Internet Logo
96 people viewed this question
Top Power Computers & Internet Experts
Gep Pep
rrackman
john smith
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
