Question about Armitron Watches
Recently bought a Armitron Roadrunner Musical pocket watch off E-Bay. Was playing music, not running. Replaced the CR2016 on top, then the 377 underneath,watch runs no music?
6ya staff
SOURCE:
cojack_1826
SOURCE: Armitron watch band needs extra links
I just called the main headquarters and they sent me 2 links for FREE!!! 1-800-840-2933 my model # for my watch is 20/1897T1 found on back. Hope this helps :)
Posted on Jan 08, 2008
HarryHarley
Harry
  • 343 Answers
SOURCE: what battery does an armitron pocket watch take
Only real way to know. Take the battery out, take it to Walmart jewelry dept and get one there @5.00
Posted on Dec 22, 2009
cmcduncand
David Duncan
  • 714 Answers
SOURCE: watch is fully wind up but doesn't run?
Several solutions:
Needs cleaning is the best possible reason.
Broken balance due to being dropped is second.
r/
David
Posted on Jan 22, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Bought iArmitron automatic watc two weeks ago, but having problem
As you are not giving any detailed explain, all I can say is to click on my profile (escapement), then click on Tips and Tricks. There you will find link to ARMITRON watch manual/instructions downloads. Find your model and read the manual carefully. You maybe doing something wrong, but manual should sort this. Rate me, plz.
Posted on Feb 19, 2010
caroldon
  • 17130 Answers
SOURCE: I have a Armitron musical
The special watch that you are having has two important parts, the first is the quartz processor/controller unit which generates the clocking signal to trigger the small stepper motor that moves the time mechanism to move the hands.
The second part is the chiming section wherein there is a chips that is embedded with a musical data memory with a small amplifier and micro buzzer/speaker.
Now within the mechanism the chime comes on when the mechanism triggers the chiming circuits as and when it is required, the time or the alarm.
Since al these are very micro which needs good experience , It can be handled only by an expert as the investigation must be very systematic to understand the reason of the drain on the cell.
A good cleaning might sometimes cure the fault, it can also be that the chime circuit is draining . But these can be confirmed with a CURRENT drain test with a series micro ammeter.
So finally I would like you to consult the nearest Armitron service centre who might have the spares than to have someone hunt around after even identifying the fault.
Check for details from the official site of Armitron.
Posted on Nov 23, 2010
How do I get the back off of a 1980s Armitron pocket watch?
the back on this pocket watch will not screw off if there's no notches for a unscrewing tool to go into, if you very carefully go round the slit with jeweler's loup you should see a small groove were you can get a stanley knife blade in the pop it off .good luck.
Nov 05, 2015 | Armitron Watches
How do I change batteries on a M.Z. Berger AW 213 watch
I know it's been a while since you posted this question, but I just had to do this with mine after it was lost in a drawer for a few years, and I had no luck googling so I had to figure it out for myself.
First, you have to remove the band, but you only need to do this on one end, not both. I did this by twisting the watch body around while holding the cloth/leather portion of the band still, letting the elastic part twist around with the watch body. Then, just use a fingernail to pull on the ridges on one end of one of the pins that are holding the band on; both ends are spring-loaded, so it doesn't matter which. Twist the watch body back around, and you'll now be able to flip it over to expose the back.
Now, take a thin, strong blade (I used a butterknife) and pry off the back plate. There's a tab on the upper right edge of the back plate to make this much easier. Since it probably came off in the process, place the rubber sealant ring back around the edge of the backplate.
Once you have the back plate off, there's a thin metal piece covering the battery that's held on with one screw. Remove that with an eyeglass screwdriver or any other similarly-sized Phillips-head screwdriver. There's just a small tab holding the metal piece in place on the other side, so just flip the metal piece up a bit and pull it out. You can now take the battery (a CR2016 3-volt watch battery) right out.
But wait, what's this? Beneath that battery, separated by a small plastic insert, is another, smaller one, a 377/376 1.55-volt watch battery. The 377/376 powers the analog movement, while the CR2016 powers all the digital stuff and the backlight.
Replace both batteries, making sure to place the plastic insert back on top of the 377/376 before putting the CR2016 back in, and follow the steps in reverse to put the watch back together. You may have some difficulty getting the back plate back on, but I just pressed one side in and held it while I tapped the other side down with my fist.
Apr 28, 2014 | Bulova Watch
Elgin watch battery
The 377 battery is located behind the CR2016 battery. You will have to completely remove the motherboard to change out this battery that runs the analog portion of the watch.
Apr 12, 2014 | Elgin Watches
I have an Armitron 20/1277-79-81 watch. I bought it at an auction, it has never been used, in fact it was still sealed in the original box. I had the battery replaced and the digital function works fine,...
many ani digi watches have to batteries , one large lithium to run the digital and then a smaller 377 silver oxide battery to run the analogue movement.
the smaller battery is usually directly below the lager battery in a small cut out in the printed circuit board.
Feb 04, 2018 | Armitron Round Digital Sport 408089 Watch
I need to know battery number for this watch.
Give us : make, model and all the writings on caseback. Photo will make it easy as well.
Aug 14, 2009 | Armitron Gold Tone Dress Watch At Kohls
Which watch battery do I use?
There are lots of different size button batteries for watches. I work in a clock shop where we change batteries in watches and I have had people bring the watches into me without batteries and it is really a guessing game. A lot of watches take a #377 battery. You can try that or take it to a place that changes watch batteries and let them figure it out.
Mar 08, 2008 | Watches
Indiana (IU) Fossil Kaleidoscope watch
It has two batteries.  The 2nd one is not obvious.
Jun 10, 2007 | Fossil Sport Washington State University...
Watches Logo
Top Armitron Watches Experts
Janelle Schoonover
Janelle Schoonover
Thomas F. Schneider
Ekse
Are you an Armitron Watch Expert? Answer questions, earn points and help others
