Question about Bertazzoni Kitchen Ranges
I have a Bertazzoni 36" 5 burner Master series range with storage drawer. I can't open the drawer
Posted by coastin42 on
Andrew Taylor
    Top Expert:
  • Bertazzoni Master
  • 33,973 Answers
It doesn't appear to have a storage drawer. Contact them direct as it must be an old model or an aftermarket drawer.
https://ca.bertazzoni.com/products/master-series/ranges/36-inch-5-burnergas-oven-2
Posted on Aug 15, 2020
3 Related Answers
Anonymous
SOURCE: viking pro gas range propane conversion
Sounds like your range is set up for the wrong kind of gas, or, in the case of LP, your installer failed to make the necessary adjustments once it was hooked up. First step is to insure that you have the proper range for type of gas you are using. If not, the orifices for all surface and oven burners will have to be changed out. That should be done by a qualified service technician.
Posted on May 21, 2008
Anonymous
  • 10 Answers
SOURCE: CD burner drawers wont open or close
sounds like a bad cd rom. as cheap as they are the best option is to replace.
Posted on Mar 20, 2009
Johnd3452
SOURCE: whirlpool electrice stove storage drawer
There is a screw in the bottom of the two back corners that holds the drawer glide in place. Remove the glide and then you'll be able put it back the way it belongs.
Posted on Jul 17, 2011
Brand new Ilve freestanding oven lost all power. Power at the wall plug.
call a repair service to check it for you .could be covered under warranty
Oct 30, 2016 | ilve Nostalgie Collection UPN90FDVGGM 36"...
My oven keeps heating. Is there anything besides the thermostat to replace?
the oven on/off switch could be bad . or the main controller
Dec 15, 2015 | Kitchen Ranges
How to remove oven door
Bertazzoni X366GGVX Stainless Steel Gas Range Remove ...
www.fixya.com > ... > Bertazzoni X366GGVX Stainless Steel Gas Range
Bertazzoni X366GGVX Stainless Steel Gas Range"remove oven door" Questions. Question about Frigidaire Kitchen Ranges. 1 Answer ..
Aug 11, 2015 | Bertazzoni Kitchen Ranges
My new Bertazzoni range leaves soot on my pots which gets on everything in close contact.
Run it through a cleaning cycle, residues from manufacturing could be causing your problem.
Apr 21, 2014 | Bertazzoni Heritage 48 Inches 6 Burner...
B3H0...A7X Propane Conversion Burners Flame Straight up
Fred did you convert both the orifices on the burners and the gas valve ? they both need it.
Oct 08, 2013 | Bertazzoni 36 in. P36500X Gas Cooktop
Bertazzoni gas range - the broiler won't stay ignited
In my case, the igniting wire was too close to another piece of metal. It was igniting upstream from the burner. All I did was push up on the wire, and the broiler started working again!
Jan 16, 2012 | Bertazzoni Kitchen Ranges
Oven won't ignite
Your range is a Direct spark model.ce00970.jpg8278a1e.pngIf you want a Direct spark manual, let me know. The module gets confirmation from relay on the oven control and sends dc power to the gas valve. I suspect that gas valve be cause the top burners work which is usually and indicator that the module is fine. The terminals ohms should be 216 ohms between each of the 3. If any are open the valve won't work.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 01, 2010 | Whirlpool GS460 Gas Kitchen Range
Kitchen Ranges Logo
117 people viewed this question
Top Bertazzoni Kitchen Ranges Experts
Dennis
Jimmy
john h
Are you a Bertazzoni Kitchen Range Expert? Answer questions, earn points and help others
