Question about Cub Cadet Garden
Cub Cadet 7235 tractor. It has a hydrostatic transmission, front loader, 3-point hitch. How do I check all fluid levels?
Posted by janet spier on
Kardoc
    Top Expert:
  • Cub Cadet Master
  • 6,080 Answers
Your owners manual would be of great help. Check this site for one.
https://www.manualslib.com/products/Cub-Cadet-7235-4222734.html
Posted on Aug 15, 2020
3 Related Answers
Anonymous
SOURCE: hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Posted on May 21, 2009
Anonymous
  • 85 Answers
SOURCE: checking fluid level
most units of this size & quality have a factory sealed transmission. to check or change oil, the transmission would have to be removed.
Posted on Sep 12, 2009
Fix4You
Philip Norris
  • 32 Answers
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Posted on Nov 14, 2010
A diagram of the transmission on a cub /zero turn/tank
Michael, The dealer may print the diagram off for you, just try asking them nicely. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cub Cadet Riding Lawn Garden Zero Turn Tractor transmission diagram Google...
Cub Cadet Riding Lawn Garden Zero Turn Tractor transaxle diagram Google...
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
https://www.cubcadet.com/wcsstore/CubCadetCatalogAssetStore/Attachment/owners%20manuals/residential/ZF50_02005033-08-1.pdf
Jul 02, 2016 | Cub Cadet Riding Lawn Garden Zero Turn...
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
you need to change thr hydr fliud in the transmission and the filter
How to add transmission fluid to Cub Cadet LT1050
If this is a hydrostatic drive, and it probably is, the transmission is sealed at the factory and requires no maintenance.
Jul 11, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Looking for the sensor schematics for a cub cadet series 1000, LT1050 hydrostatic lawn tractor. anyone help me?
Try looking at the directional lever at the Transmission. The PTO for the deck will shut off when shifting into reverse. You may have to simply disconnect or jumper the reverse switch depending on if it is normally closed or normally open. Try it both ways to see what works. Also check the engine oil level, The low oil level switch will shut the engine down if more than a quart low.
Feb 27, 2018 | Cub Cadet Lawn Mower Deck Drive Belt...
Cub Cadet IH 382 Hydro
There is a drain plug on bottom of transmission.I believe it had a 9/16 head I know my Cub Cadet required me to remove the seat to make it easier.
Apr 10, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My cub cadet i1042 drive shaft won't engage ... The clutch or coupler is bad ???
hello reut... most of the cub cadets have a hydrostatic transmission. that said, keeping the transmission fluid full is key to good operation. Check the tranny fluid and add as much as you need to bring it to spot on full. joe
May 22, 2011 | Garden
Cub cadet hydrostatic transmission new lawn mower, hydro growls pretty bad when taking off, is this normal for the 1045 or 2045 series?
check the hyro oil level is up to the correct mark. but some hydro units make a noise if you set off on full revs quite rapidly
Jun 11, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet (105, I believe) hydrostatic transmission problem
you may want to pull the check valves out and make sure the ball arnt stuck if thay are it will do that just lube theme up with some wd40
Apr 20, 2010 | Garden
Garden Logo
136 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
Marvin
Marvin
Dennis Key
Dennis Key
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
