Technika lcd 40-270 tv The "menu" Keeps flashing on the screen and the blue light keeps blinking. What is the cause and possible fix as I don't really want to have to buy a new TV
Posted by Jon on
ray gallant
    Top Expert:
  • Televison & ... Master
  • 69,148 Answers
There are many problems that repair shops fix as an old self taught fixer i gave up on self fixing when they switched to transistors and diodes could not afford the testing equipment then or now
Posted on Aug 16, 2020
5 Related Answers
Buddy Mcsparrin
  • 1684 Answers
SOURCE: Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Posted on Jun 17, 2009
Anonymous
SOURCE: Technika flat screen: will not switch on.
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Posted on Apr 18, 2010
Anonymous
SOURCE: Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Posted on May 05, 2010
Anonymous
SOURCE: technika lcd 19dvdid-207 won't turn on. flashing red light
Try D103, usualy goes S/C!
Posted on Jun 09, 2010
Anonymous
  • 7 Answers
SOURCE: I have a Tevion 32"
there is a firware update available from AWA
ernie.awa.com.au/TV/default.aspx
fixed my set with the same problem
cheers
Posted on Sep 22, 2010
The menu keeps flashing on and off. I have turn the tv off 4 or 5 times but it still keeps flashing the light on the bottom of tv goes blue then red really fast
How old is your TV? This normally indicates a power problem. It could be any of the following: power supply on the TV, faulty power strip, faulty wall outlet, faulty circuit board inside the TV, faulty power cord/plug, bad airflow/clogged vents restricting air movement into the TV (can cause intermittent power faults),bad sensor inside TV. This is not completely inclusive by any means. It does mean that you should have it looked at. Someone knowledgeable/skilled should be able to determine the cause fairly quickly using a multimeter.
Apr 25, 2017 | Televison & Video
Technika tv lcd 37-207 wont switch on blue light keeps flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 26, 2014 | Televison & Video
Technika lcd 32-207 television powers up but will noit come on blkue light keeps flashing
Hello.
if the blue lights keep flashing you have shorted parts inside. usually the inverter board have a shorted IC, try to remove the connector from inverter then try again..
if your blue lights lit replace the inverter which you disconnect.
Dec 06, 2012 | Televison & Video
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
The menu keeps flashing all settings and the control buttons will not operate the tv
Flashing of the led light in the front panel indicated the parts malfunction inside the set. Let me know if you're handy with electronics and I will guide you to fix it yourself. Count how many blinks does the led light to determine the exact caused of the fault.
Fell free to ask question.
Jdvillanueva
May 12, 2011 | LG 32LG30 32 in. LCD HDTV
Technika flat screen: Will not switch on, the blue standby light just flashes
Apr 14, 2010 | Televison & Video
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
