Question about Furniture
Noisy compressor on my vintage 7 up cooler . Works good but loud .
Posted by Lynden Cameron on
1 Related Answer
Anonymous
  • 87 Answers
SOURCE: Khtu100kss is very loud .
Hey..... It works.... thats what counts
Posted on Oct 14, 2010
Cooling system capacity
First, check with either a volt meter or a circuit tester light rated for the voltage of your cooler if you have voltage to the compressor. Your problem may be a faulty temperature control thermostat or a compressor.
I hope this helps you, good luck!
Mar 26, 2014 | Vintage Keeper Furniture
Noisy compressor?
My Gdm 12 was doing the very same thing. Remove the from grill plate by taking out the 4 screws below the door. This will expose the compressor mounting plate . While the compressor is running, and is at its loudest, loosen or tighten the two front hold down bolts until the noise goes away. Most likely, when you cooler was moved or transported off the shipping pallet, it was bent slightly allowing contact between the bottom of the compressor, and the mounting plate. Hope this helps.
Feb 03, 2014 | True GDM-12 Refrigerator Commercial
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
Why are wine coolers so noisy?
Compressor-run wine coolers may be slightly noisy at times; however thermoelectric coolers are completely silent.
Jul 31, 2012 | Furniture
What does compressor getting noisy on ocaisson mean? Do I need to assume failure is immenient or could it last a while longer?
It is hard to say how long any appliance will last, but I would not replace solely for a noisy compressor. Most all compressors with age will get noisy on start up and shut down. If there is an espically loud knock on shut of check the mount bushings or for broken/lose mounting hardware
Sep 17, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Jul 18, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Beverage Air ST58N Not cooling
Compressor is cycling on the overload protector. Cause could be a bad starting relay but is more than likely the compressor is bad.
Jun 11, 2008 | Carrier ST58N
Koolspace wine cooler
I have the Vintage Keeper Odyssey. I had the same thing the other day. Unit is 7 years old. Vintage Keeper web-site suggested to unscrew the control box and remove. (The box with the "Set" and Up and Down arrows. Unplug the wiring and sensor on the back and then plug back in. Plug in the unit and text. It took my "AL" away.
Unit doesn't cool very well. A coolant leak may be my problem. I was looking for solutions other than buying a new refrigeration unit.
Jun 07, 2008 | Vintage Keeper Koolspace chillR Cooling...
Furniture Logo
118 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
