Cars & Trucks Logo
J
Jonah Jackson Posted on Nov 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
John Deere Gator. Reverse works fine. Neither forward gear works.
If battery connections are reversed, wheels will spin in forward direction when in reverse. Nothing in forward gears. Switch assembly has been apart and cleaned Forward switch has no resistance between center and front back poles as appropriate. Jumpered the thermal switch, and jumpered various combinations on the forward switch as if switch was closed, can't get anything to move the wheels forward. Have thing apart, with voltage directly to motors they will both spin Forward or Backward as appropriate. What am I missing
Vernon Taylor
Level 3:
  • Cars & Trucks Master 7,446 Answers
  • Posted on Nov 06, 2019
 Vernon Taylor
Level 3:
Answers
7446
Questions
0
Helped
1959637
Points
26207
Assume this is an electric vehicle?
The days of electric vehicles having a rheostat speed control and huge switches to change motor direction are far behind us.
Most modern electric vehicles employ a good deal of electronics with a switch mode power supply for speed regulation which controls hefty semiconductor devices. The forward/reverse switch would typically engage/disengage either relays or more semiconductor devices.
These devices are often placed on a common circuit board and any problems will need specialist investigation, repair or replacements. It is most unwise to reverse battery polarity when electronics are present - it is likely by doing so you have increased the repair cost...
5 Related Answers
kirkx
Kirk Augustin
  • 2019 Answers
  • Posted on Jun 26, 2009
SOURCE: 1999 F250 only goes in reverse, no forward gears.
I believe that reverse is operated by a brake band. So it seems to be stuck. It is operated by a piston, and the seal could have swelled and caused too much friction. But you could loosen up the adjustor so that it is disengaged, in order to get forward gears again. Perhaps you can force the piston to retract as well, once you drop the pan again.
Anonymous
  • 521 Answers
  • Posted on Jul 18, 2009
SOURCE: I have a 1999 Cadillac Esclade,Automatic Transmission
internal transmission problem. Unless you know how to rebuild a transmission it is best to take the dealr or a transission repair shop like AAMCO.
Anonymous
  • 11 Answers
  • Posted on Sep 04, 2009
SOURCE: 1988 Jaguar xj6 No forward in the automatic trans rev works fine
the linkage is just a slight bit off, it parks between gears when you shift into the slots. Disassemble the shifter from the center console, and slowly move just the cable its self between the positions and see if you have forword gears. When you find and sync the gears, then tighten the cable to the shifter so the positions match the notches in the shifter.
Anonymous
  • Posted on Jan 22, 2010
SOURCE: no reverse gear
This question should be deleted. Aside from the obvious illiteration, there is nothing in the known universe that could be stuck in an oil filter that could cause the transmission to fail, nor could the oil pressure. What most likely happened is someone did a neutral drop and blew a solenoid in the transmission. Rebuild/replace transmission, or drive without it.
Anonymous
  • 635 Answers
  • Posted on Mar 07, 2010
SOURCE: turbo 350 trans no forward gears but does have reverse
It's either your servo, or your bands.
Either way, the tranny needs a good cheap shop repair.
I'd just get a warrantied salvage yard tranny if I were you and save a few hundred bucks.
50 horse 4 stwont go into reverse gear due to shaft problems
the drive shaft just drives a pinion gear in the prop box that drives to gears that spin in opposite directions all the time
by selecting forward with the selector rod , a dog gear is moved forward to mesh with one gear that is turning or moves the other way to engage the other gear that is turning
that is the forward or reverse action for the prop
if you have forward but no reverse the it is not a drive shaft problem but a selector rod adjustment that is not moving the dog far enough to engage the running gear
The car has an automatic transmission and all of a sudden i had no reverse had no slipping or nothing the drive gears work fine no slipping grinding nothing shifts through all gears just fine
It may just need servicing/adjusting.
Your reverse gear is actually first gear ... when you select reverse another 'cog' fits into the toothed wheels to change the direction of first gear ... to give you reverse...
It may be a sticky valve or just a bit of adjustment (workshop job..) that is required.
What you can try ..
Start the car ... move the lever through all the positions several times (foot on brake..). Keep your foot on the brake and then put it in reverse and rev the car. Hard!
Try doing it several times.
An auto transmission works on valves opening and closing. Reverse gear - in comparison with the forward gears - is seldom used. The reverse valve can 'stick'. Try forcing it to open ... frighten it ... but keep your foot on the brake...
95 mustang v6 auto no forward gears but works in reverse had ****** rebuilt and same thing
Maybe your differential is shot and will only allow reverse spin or the transmission was not really rebuilt professionally. Was the transmission checked outside of your car after rebuild? Does your vehicle have a Powertrain Control Module (PCM)? Maybe the module went bad or faulty.
3helpful
I have a 2000 Expedition 4.6L Triton. I've had truck about 7 years and love it. I have had all the transmission issues this truck can have...(I thought) until now this: SYMPTOM Transmission drives well in...
4R100 or 4R70W?
Geartrain
Power is transmitted from the torque converter to the geartrain components through the input shaft and forward clutch cylinder.
  • By holding or driving certain members of the gearset, four forward ratios and one reverse ratio are obtained and transmitted to the output shaft. The ratios are as follows:
GEAR RATIO 1ST 2.71 to 1 2ND 1.54 to 1 3RD 1.00 to 1 4TH 0.71 to 1 REVERSE 2.18 to 1
Input Shaft
The input shaft is supported by two bushings in the stator support. End positioning of the input shaft is controlled by the splines in the converter turbine and the overdrive planet assembly.
Output Shaft
The output shaft is supported by two bushings in the case and by the slip-yoke and bushing in the extension housing. End positioning is controlled by the parking pawl gear and snap ring or shoulder and by the reverse ring gear hub and snap ring.
Overdrive System
The overdrive planetary system consists of the overdrive planet assembly, overdrive sun gear, overdrive ring gear, coast clutch cylinder, overdrive one-way clutch assembly and the center shaft, as shown in the following illustration. The overdrive planet assembly is splined to the input shaft. The overdrive sun gear is centered by a bushing on the input shaft and held in place laterally by needle bearings on the reactor support and the overdrive planet assembly. The overdrive sun gear is splined to the coast clutch cylinder, which in turn is splined to the overdrive one-way clutch inner race.
The outer race of the one-way clutch is splined to the overdrive ring gear, which is splined to the center shaft. The center shaft is centered by the forward planetary assembly and is laterally held by needle bearings on the center support and the overdrive planet assembly. The center shaft is splined into the forward clutch cylinder.
Two friction clutches are assembled in the overdrive planet assembly. The coast clutch is splined between the coast clutch cylinder and the overdrive ring gear. The coast clutch is activated to perform engine braking in MANUAL 1, MANUAL 2 and third gear with the transmission control switch engaged.
The overdrive clutch is splined between the case and the coast clutch cylinder. The overdrive clutch holds the coast clutch cylinder and, in turn, the overdrive sun gear, to permit the planet assembly to overdrive the ring gear.
Forward Drive System
The forward drive system consists of the forward clutch cylinder, intermediate brake drum, intermediate one-way clutch, input shell, forward ring gear, forward ring gear hub, forward/reverse sun gear and the forward planetary carrier and forward planetary gears.
The forward clutch cylinder is splined on the center shaft. The forward ring gear is piloted on the forward ring gear hub. Thrust bearings on the forward planet assembly and forward clutch cylinder hold the forward ring gear hub in place.
The intermediate brake drum is radially supported by bushings on the center support and is laterally controlled by thrust washers on the forward clutch cylinder and center support. The intermediate brake drum has the inner race of the intermediate one-way clutch press-fitted on its pilot. The intermediate one-way clutch's outer race is splined to the intermediate friction clutch, which is splined to the case. The intermediate brake drum has lugs that are slotted into the input shell to form a mechanical connection. The input shell is splined into the forward/reverse sun gear. The forward/reverse sun gear is common to two planetary gearsets. The forward planet is splined to the output shaft and is laterally positioned by needle bearings on the sun gear and on the forward clutch cylinder, as shown in the following illustration.
Two friction clutch assemblies, the direct clutch and the forward clutch, are shown with the forward planetary assembly. The direct clutch assembly splines the forward clutch cylinder to the intermediate brake drum. The forward clutch assembly splines the forward clutch cylinder to the forward ring gear. The forward clutch is activated during all forward gears. While in third or fourth gear, both the direct and forward clutches are applied to hold the forward planetary assembly and enable it to act as a solid shaft.
In second gear, the intermediate clutch assembly holds the forward/reverse sun gears. It is applied, along with the intermediate one-way clutch, to hold the intermediate brake drum, input shell and forward/reverse sun gear. In higher gears, the one-way clutch overruns.
Low and Reverse Drive System
The reverse planetary assembly consists of the reverse planetary carrier, reverse planet gears, the reverse ring gear, the reverse ring gear hub, the reverse clutch hub and the low-reverse one-way clutch assembly.
The reverse ring gear hub is splined to the output shaft and to the reverse ring gear. The reverse ring gear hub is laterally held by a needle bearing on the inner race of the low-reverse one-way clutch and a snap ring on the output shaft. The reverse planet assembly is splined to the low-reverse clutch hub. The low-reverse clutch hub is connected by the reverse clutch to the case. The inner race of the one-way clutch is bolted to the case.
The reverse clutch assembly is activated in REVERSE gear and in MANUAL 1. The reverse clutch bypasses the reverse one-way clutch during coast and MANUAL 1. The reverse clutch holds the reverse planet assembly in REVERSE gear to enable the sun gear to drive the reverse ring gear in the opposite direction.
Apply Components
The following information describes the operation of the three 4R100 one-way clutches.
One-Way Clutch—Overdrive
The overdrive one-way clutch, shown in the following illustration, transmits engine torque from the overdrive sun gear to the overdrive ring gear in first, second and third gear range. The overdrive one-way clutch transmits power when the sprags are engaged between the inner and outer races. The inner race is splined to the coast clutch cylinder, which in turn is splined to the overdrive sun gear. The outer race is splined to the overdrive ring gear.
The overdrive one-way clutch engages whenever the overdrive planetary system attempts to drive the overdrive sun gear clockwise when the overdrive ring gear has a counterclockwise torque from the vehicle. When torqued counterclockwise, the overdrive one-way clutch engages and acts as a wedge to lock the sun gear and the ring gear together. During coast, the overdrive one-way clutch enables the ring gear to overrun or spin at a faster rate than the sun gear.
The overdrive one-way clutch overruns when in overdrive (fourth gear). In overdrive, the coast clutch cylinder is held by the overdrive one-way clutch, which in turn holds the overdrive sun gear. This causes the overdrive planet assembly to walk around the sun gear and overdrive the overdrive ring gear. The inner race of the overdrive one-way clutch is thus held stationary while the outer race is allowed to overrun clockwise.
3helpful
I have a 97 VW Golf auto trans, I have no reverse gear, no noise when placed in gear it just wont move, all forward gears work fine, any ideas for me
Check your fluid level to make sure its up to the specified level, then I'd be checking out your linkage from your shifter inside the car right to the transmission, it sounds like to me your linkage may be worn enough to put the vehicle in drive but not reverse. The linkage bushings are a common problem on vdubs. See if you can put the car in reverse by moving the linkage arm directly attached to the transmission (make sure you have someone in the car with the brakes on or caulk the wheels) if it does go into reverse when you manually move the direct linkage arm at the transmission then replace your linkage bushings, if not then the only other problem would be a transmission internal problem. Good luck
vdubs 4-ever
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
