Master
- Posted on Sep 18, 2009
Re: Need to know how many turns do i turn out the needle...
ADJUSTING THE IDLE SPEED AND MIXTURE
On some float-type carburetors, you can adjust the air-fuel mixture
and engine speed at idle. Check for an idle speed screw designed to
keep the throttle plate from closing completely, and an idle mixture
screw that limits the flow of fuel at idle. If your carburetor contains these screws, proceed below.
- With the engine off, remove the air filter and air cartridge.
- Locate the idle mixture screw and turn it clockwise
until the needle lightly touches the seat. Then, turn the screw
counterclockwise 1-1/2 turns.
- If your carburetor has a main jet adjustment
screw at the base of the float bowl, turn the screw clockwise until you
feel it just touch the seat inside the emulsion tube. Then, turn the
screw counterclockwise 1 to 1-1/2 turns. Replace the air cleaner
assembly and start the engine for final carburetor adjustments.
- Run the engine for five minutes at half throttle
to bring it to its operating temperature. Then, turn the idle mixture
screw slowly clockwise until the engine begins to slow. Turn the screw
in the opposite direction until the engine again begins to slow (image A). Finally, turn the screw back to the midpoint.
- Using a tachometer to gauge engine speed (image B),
set the idle speed screw to bring the engine to 1750 RPM for
aluminum-cylinder engine or 1200 RPM for engine with a cast-iron
cylinder sleeve.
- With the engine running at idle (image D),
hold the throttle lever against the idle speed screw to bring the
engine speed to "true idle." Then, repeat the idle mixture screw
adjustments from Step 4 to fine-tune the mixture (image C).
