Question about Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor
I have a k9 mundial 3 car alarm system and the keyless lock doesn't work anymore.
Posted by darryl_vrees on
2 Related Answers
Anonymous
SOURCE: crimestopper keyless entry remote wont unlock or lock anymore changed battery still wont work
need to program a new remote to keyless entry system it is crimestoppper cs835 rke
Posted on Dec 16, 2009
iadame
Israel Adame
  • 676 Answers
SOURCE: only one of my my k-9 mundial keyless work the
Try to reprogram the remotes to the alarm. Have your vehicle key and both remotes ready. The way to do this is as follows:
1. Turn ignition key to run position.
2. Within ten seconds push the valet button 5 times.
3. The siren will give a chirp, indicating that you are in programming mode.
4. Press the large button on the first remote. A chirp will be given as confirmation.
5. Press the large button on the second remote. A chirp will be given as confirmation.
6. Turn off ignition and remove key. Alarm will give long chirp indicating exiting program.
7. Try remotes. Both should be working.
For the next 48 hours, every time the vehicle is starting the siren will chirp indicating that remotes have been programmed. After 48 hours this feature will turn itself off. Also keep an eye on the alarm light as it will also blink the number of times as remotes are programmed every time the ignition is turn on.
Hope this information helps. Please rate. Thank you.
Posted on Mar 04, 2010
My 2000 grand vitara alram wont stop going off what can I do to stop it
a lot of times car alarms go off when they since a voltage drop in the vehicles battery test or replace cars battery
Jun 01, 2012 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
My K9 alarm is silent. I am not hearing the noise when I open the doors are close them. How can I activate this feature again?
Is the LED indicator illuminated steady (not flashing)? If it is, than the system is in valet mode. In order the turn off valet mode, you need to press and release the valet button once. The LED should turn off and you will be able to operate the security system.
Jan 23, 2011 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
How to turn kill switch off and see manual and instructions
I am assuming that you want to disable the system temporarily by putting it in valet mode. You will need to locate the valet button; they are usually installed under the dash within reach of the driver. The button should be black and about 1/2" in diameter.
Pressing and holding the button for 3 seconds while the alarm is disarmed will put the system into valet mode. The system will turn the LED light on steady and chirp the siren to indicate that valet mode has been activated. To exit valet mode, press and release the button. The LED will turn off and the siren will chirp to indicate that you have exited valet mode.
The included link is for the manual, see page 8.
http://www.caralarm.com/manuals/K-9/K9-Mundial-ss.pdf
Nov 03, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Only one of my my k-9 mundial keyless work the other seems fine but wont activate.
Mar 04, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Car does not start lights flash 3 times
can you be a little more specific. Are you talking about a remote starter???
Feb 05, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Trying to program a new remote to my car alarm ''excaliber'' k9 remote
turn key to on position push valet 5 times then hit lock on the remote
Dec 26, 2009 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor Logo
679 people viewed this question
Top Dual Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Dual Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
