Question about AT&T Cell Phones
I need the apn settings for my at&t zte life wireless
Posted by Lynn Fuson on
Ray
    Sergeant:
  • 324 Answers
You chould contact your cellular provider and ask them for it.
or you could try these:
APN: wap.cingular
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: [email protected]
Password: cingular1
Server: <Leave in Blank>
MMSC: http://mmsc.cingular.com
MMS proxy: wireless.cingular.com
MMS port: 80
MCC: 310
MNC: 410
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
Taken from here:
https://apn-settings.com/us/att-apn-settings/
Posted on Feb 04, 2020
5 Related Answers
heathercr14228
Heather Crossman
  • 3 Answers
SOURCE: Net10 APN Settings for ZTE Midnight?
Tap the Home Key > Menu Key > System settings
Posted on Jul 01, 2014
Erik Walters
  • 155 Answers
SOURCE: I have a zte z832 unlocked cricket phone and I put my life wireless SIM card from the lifeline free phones in the phone and need to set the APN ..does anyone know the APN to set to this phone?
  • type it in exactly as it appears below.
  • APN: wholesale
  • APN type: default,mm,supl
  • Proxy: not set
  • Port: not set
  • Username: not set
  • Password: not set
  • Server: not set
  • MMSC: http://wholesale.
    mmsmvno.com
    /mms/wapenc
  • MMS Proxy: not set
  • MMC: 310
  • MNC: 260
  • Authentication type: not set
  • APN Protocol: IPv4
  • APN roaming protocol: IPv4
  • APN enable/disable: APN enabled
  • Bearer: unspecified
  • MVNO type: none
  • MVNO value: not set
Press the Menu key and save. Reboot your phone and test your data connection by opening a web page.
Posted on Oct 20, 2017
hanlondr
Dan Hanlon
  • 52 Answers
SOURCE: Apn settings for safetynet wireless lifeline on my kyocera zte N3192
APN & data settings
  1. From any Home screen, tap Apps.
  2. Tap Settings > More > Cellular networks.
  3. Tap Access Point Names.
  4. If available, tap the T-Mobile US APN.
    • If not available, tap the New APN icon.
    • To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
  5. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: default,supl,mms
    • APN protocol: IPv6
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
    • MVNO type: None
    • MVNO value: <Not set>
  6. Tap the Menu icon with three dots, then tap Save.
  7. Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
  3. Tap Network operators.
  4. Wait while the device populates a list of available networks.
  5. Tap the desired network you wish to register on.
Switch 2G / 4G
  3. Tap Preferred network types.
  4. Choose from the following options:
    • LTE/WCDMA/GSM (Auto mode)
    • WCDMA/GSM
    • GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
  1. From any screen, swipe down from the top of the screen.
  2. Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
  3. Tap to turn Data Roaming on or off.
Turn on / off mobile data
  1. From any Home screen, tap Apps > Settings > Data usage.
  2. Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547
If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
Posted on Mar 22, 2018
mattdehat
matt
  • 1621 Answers
SOURCE: What are the APN settings for life wireless Samsung J3 prime
please see the link
3 APN settings for Samsung Galaxy J3
Posted on Sep 24, 2018
josh_prui37822
Some Dude
  • 135 Answers
SOURCE: life wireless apn settings for at&t huawei ascend xt2 H1711
APN & data settings
    • Name: T-Mobile US
    • Proxy: <Not set>
    • Port: <Not set>
    • Server: <Not set>
    • MCC: 310
    • MNC: 260
    • Authentication type:<Not set>
    • MVNO type: None
Switch 2G / 4G
    • WCDMA/GSM
    • GSM only
  1. From any Home screen, tap Apps > Settings >Data usage.
From - https://support.t-mobile.com/docs/DOC-28547 Network APN Kyocera DuraForce XD
Posted on Oct 04, 2018
APN & data settings
    • Name: T-Mobile US
    • Proxy: <Not set>
    • Port: <Not set>
    • Server: <Not set>
    • MCC: 310
    • MNC: 260
    • MVNO type: None
Switch 2G / 4G
    • WCDMA/GSM
    • GSM only
Mar 21, 2018 | Kyocera Cell Phones
  • APN: wholesale
  • Proxy: not set
  • Port: not set
  • Username: not set
  • Password: not set
  • Server: not set
    mmsmvno.com
    /mms/wapenc
  • MMC: 310
  • MNC: 260
  • MVNO type: none
Oct 20, 2017 | ZTE Cell Phones
Life wireless apn settings for at&t kyocera duraforce e6560
The best place to get these settings is from your service provider. Call up on their customer care hotline and ask. They'll send an SMS containing the settings.
Jun 20, 2017 | AT&T Cell Phones
Life wireless APN setup - Cell Phones
From the Home screen: Swipe right-to-left across the screen to open the Apps list. Scroll down and tap Settings. In the Settings menu, tap Network & wireless. Tap Mobile & SIM. Scroll down and tap SIM settings. At the bottom of this page, you will find separate buttons to add the Internet and MMS APNs.
May 16, 2017 | Cell Phones
I have a at&t htc 610 that's with life wireless now and I need the apn settings to send and receive mms and surf the Web . Can anyone help please?? Asap!!
Go to Settings>Mobile data>Access point names then press Menu and select New APN. Then enter these settings:
APN: tslpaymnet
Proxy: 'Leave blank'
Port: 'Leave Blank'
Username: 'Leave Blank'
Password: 'Leave Blank'
Server: 'Leave Blank'
MMSC: http://mms/
MMS Proxy: 193.35.133.194
MMS Port: 8080
MMS Protocol: 'Leave Blank'
MCC: 234
MNC: 33
Authentication type: PAP
APN Type: internet+mms
Jan 19, 2016 | HTC Cell Phones
I cannot receive any text messages that contain a picture
There are a few things to do that may fix your issue:
1. Delete text messages off of your phone (especially if you have hundreds of texts to one recipient)
2. Go to settings in your "messager" app and reset setting to default.
3. Make sure your APN settings are correct:
Go to "Settings"
Select "More networks"
Select "APN"
Edit your currently used apn...
APN: wap.cingular
Proxy: none
Port: none
Username and password are blank
Server: none
Mmsc: http://mmsc.cingular.com
Mms proxy: wireless.cingular.com
Mms port: 80
Mcc: 310
Mnc: 410
Authentication type: none
APN type: default
Oct 05, 2015 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
Cant recieve or send out mms
Here are the APN settings for your phone and T-Mobile.
These need to be correct for mms to work.
APN & data settings
To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Wireless & networks.
  4. Open the Access Point Names or APNs. menu (in steps above)
  5. If there is a T-Mobile APN, touch it. If not, press the Menu key, and touch New APN.
  6. Verify and update the following settings for the Data APN:
    • Name: T-Mobile
    • APN: epc.tmobile.com or fast.t-mobile.com (for LTE devices)
    • Proxy: <Not set>
    • Port: <Not set>
    • Server: <Not set>
    • MCC: 310
    • MNC: 260
    • APN type: <Not Set> OR Internet+MMS (depending on software version)
  7. Press the Menu key.
  8. Touch Save.
  9. In the list of APNs, delete all others that may appear. If there is a FOTA APN, you may leave that one. To do this:
    1. Touch the APN you want to delete.
    2. Press the Menu key.
    3. Touch Delete APN.
  10. Verify that there is a circle next to the one remaining APN to show it is activated.
  11. Perform a soft reset.
  12. Test your data connection, by accessing a web page or sending a picture message (MMS) to yourself.
Sep 15, 2014 | ZTE Concord Blue Smartphone - T-Mobile 832...
Cell Phones Logo
77 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
