Question about Tablets & eReaders
On Azpen tablet A1046 My wifi button won't turn on even after factory resting and wifi rest how can I fix
6ya staff
SOURCE:
sumitshiv420
sumitshiv420
SOURCE: need to factory rest my mid m9000 android tablet
i am frget my password peeeeeeeeeee halp my
Posted on Mar 25, 2013
ngiateng
IMDante
  • 141 Answers
SOURCE: My son accidentally hit the factory rest button on
Reset it again and select English.
Posted on Nov 24, 2013
Gracia Lobaton
SOURCE: how do you factory rest this tablet?
Just go Settings > Back up and reset > Factory data reset.
Posted on May 10, 2014
mileso
Mike M
  • 3324 Answers
SOURCE: How to factory rest my hamswan allwinner a23 7inch
Try this:
https://www.youtube.com/watch?v=xSM8k4LIeQE
Posted on Sep 23, 2014
dreifurst5
Jason Dreifurst
  • 16 Answers
SOURCE: Azpen a840 won't get WiFi & other tablets do
Go to WiFi setting gs n empty all n take a look at you at the restrictions n fix it
Posted on Sep 27, 2014
I forgot my password for my tablet azpen model A746G what should i do?
To perform a factory data reset on your Azpen tablet, you need to backup files first from your device because it will delete all data. If you are through, you have to switch it off. Hold the volume button while you press the power button for ten times. Then press the reset button four times. Then release all buttons when it switches on. If you see the Android symbol and triangle on the screen, use your volume keys to navigate through the recovery menu. Select Wipe data/Factory data reset. Use power button. Select delete all data. Then select reboot now.
Still have any issues, you must go to customer care at +1-800-243-0051
Apr 27, 2017 | Tablets & eReaders
I fix the broken screen on my RCA tablet and now my Wi-Fi won't work.
Droid Pro: wifi won't turn on - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Motorola Droid Pro
Dec 17, 2012 - 25 posts - ‎23 authors
Ok so I tried to turn on my WiFi in the settings and it would say turning on ... myphone, done a factory reset and even used a WiFi fixing app. ... wifi fixer doesn'twork. ... to lock my phone without the screen staying on for 15 seconds or so. ... I was having trouble turning on wifi on my tablet and one of the post ... Auto Rotate does not work.
May 11, 2014
New Tablet/Authentication Problem with Wifi
Dec 17, 2013
WiFi stuck "turning on"
Aug 18, 2013
More results from forums.androidcentral.com
Android Tablets Forum - Tom's Guide
Dec 15, 2015 | Tablets & eReaders
How to fix white screen upon turn on
if it has not been dropped or water damaged you can try a factory rest ( loosing everything ) Turn off tablet and hold the volume up button and the home button together,then turn the tablet on ( keep holding the volume up and home button ) when tablet starts it will show you a secret menu, you can try rebooting it first from that menu and if it still dose the same thing,if it dose then repeat the steps again but go for reset. ( this will wipe it clean,you will loose everything,so only do that as a last resort ) hope this helps
May 27, 2015 | Tablets & eReaders
My tablet screen is frozen on the screen that reads azpen.when i turn it off and back on it is still frozen.it will not take a charge nor if i leave it on will the battery die.what can i do?
Hard Reset
Press Vol-up&Vol-Down button at same time, Then press the power button.
This starts your devices Recovery Mode.You can do a Wipe/Factory Reset from there. Use the Vol Up&Down buttons to navigate and the power button to select.
Be Careful and DONT MESS with the Other options or you may Brick your phone.
Apr 12, 2015 | Azpen 03038 A9 9.7" 8gb Android tm 4.0 Os...
Sep 27, 2014 | Tablets & eReaders
Wifi button won't stay to on.
mine does the same thing. have you found out how to fix it. ive even tried doing a factory reset and that didnt even help.
Dec 14, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
My tablet turns off by itself even though it has 97% of charge!!!!!!!!!!
Make sure the case is not resting on the power button. Also, from personal experience, make sure when you hold it, you hand does not rest on the power button.
Oct 14, 2013 | Tablets & eReaders
How to rest an ipad
To reset,press the home button and sleep/wake button at the same time and hold for at least 10 seconds.the iPad should then reset itself.
Sep 09, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
