Question about Sewing Machines
My automatic threader on my Cresendo Babylock machine is not threading the needle. I has always worked until yesterday. I have tried several different quilting needles...
Posted by Becky Genrich on
umesh bhatt
    Habit-Forming:
    New Friend:
  • 53 Answers
Check the alignment of the threading head which comes near the needle eye and threads and goes back. There must be some minor adjustment for that. Do not force it as it would bend.
Posted on Aug 16, 2020
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
SOURCE: Needle Threader is not lined up
This is called the Needle Threader Plate.
If this is too small for you to read, or you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
Anonymous
  • 6 Answers
SOURCE: problem with automatic needle threader On Viking Designer 1 serie
Yes, I fix them all the time. You will need very good eye sight as the wire/metal hook is very small. If you get at an angle where you can see how the hook lines up between the metal flaps that hug the needle, the hook will probably be off center. You will need something very flat, but strong. I have use the exact-o-knife blade, in the handle of course, a knife, and a tiny screw driver. The hook has to line up vertically and horizontally. What usually happens is when we thread the needle it did not line up exactly, and putting pressure on the white tab, bends the hook. Bend it back and you are in business. If the threader does not line up horizontally, the needle threader may have slid down the shaft. This take a special tool. I purchased mine at Sears tools. There are 2 screws on the back of the threader. Move the needle to the highest position and after loosening the 2 screws, you can slide the threader up and down on the silver shaft, this is trickier, because the shaft moves up and down and rotates as it gets close to the needle. I use calipers/hemostats to hold the shaft while I line up the hook.
Hope this helps.
Posted on Jan 07, 2009
Anonymous
  • 34 Answers
SOURCE: automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Posted on Jan 31, 2009
Ruth Peck
  • 69 Answers
SOURCE: Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
Posted on Feb 09, 2009
paj42
  • 1116 Answers
SOURCE: AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
Posted on May 01, 2010
I have a Babylock BMP9 6 needle embroidery machine. The automatic needle threader mechanism is not dropping down far enough to use to thread the needles. Any suggestions on how to fix this?
On older machines that do not have the automatic needle-up feature, the user needs to manually adjust the needle height so the threader will match the needle eye.
Oct 29, 2016 | Sewing Machines
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
There's nothing wrong with the Threader, it's just that the Threader doesn't reach the back of the Needle!
Usually you have to manually move the needle up and down until its height matches the threader height. Newer machines have an automatic needle stop that generally matches the threader but most older machines need to be manually manipulated.
HINT: If you do need to manually thread your needle, lick your index finger and then rub the back of the needle's eye. Your thread will literally "leap" through the eye! This works for hand-sewing needles too!
Feb 03, 2016 | Singer 8763 Curvy
Can the automatic threader be fixed can i do it myself?
Depends what is wrong with your needle threader. Needle threaders tend to be very fragile parts so it is not uncommon for them to stop working. You may be able to replace the part if it is broken but it may be a job trying to find the part. Search the internet for parts for the make & model of your machine. Once you get the part, search the internet (YouTube) for videos showing how to replace the part.
On the other hand, it is not a serious problem if the auto-needle threader does not work. These options were not available until the most recent sewing machines were manufactured and your machine will most likely operate for many years despite the broken needle threader. Manual threading was all that was available for over 100 years.
HINT: To help make needle threading easier, lick your forefinger then swipe the back of the needle's eye. The moisture in the eye will help pull the thread through.
Nov 11, 2015 | Sewing Machines
Top thread is shredding Automatic needle threader stopped working
If the top thread is shredding it is usually because the needle and thread are not compatible. If thread is too large for the eye and the thread groove, the action of sewing will cause the thread to shred as it pieces the fabric.
Try a different needle and thread. Here's an excellent web site:
All About Needles
Sep 27, 2015 | Sewing Machines
I cannot get the CE-250 automatic needle threader to work. Threader and needle do not align up together.
Always make sure you rotate flywheel to raise the needle to its highest position before trying to use the threader. additionally the correct needle has to also be used so the threader wire and needle eye line up properly.
Cheers,
Embroidery Services
San Diego, CA
Sep 17, 2017 | Singer Sewing Machines
Auto Needle Threader Won't Come Down
If it's still in warranty, send it in for repair. If it's not still in warranty, pull out a length of top thread and clip off the end with sharp scissors at an angle. Poke the end of the thread through the needle eye -- it should go through easily. Two second solution.
Jan 09, 2014 | Singer 3116 Simple
Automatic needle threader won't work on brother pe-770
Always make sure the hand wheel is at the exact top. Have you replaced the need recently? If it's bent, then the threader will not work. If the needle is loose or not all the way to the top in the holder, it will also cause the threader to not work.
Jan 06, 2013 | Brother PE770 Computerized Sewing Machine
How do I use the automatic threader? The diagram in the instruction manual just shows the threader but doesn't show how to get the thread in.
When you have the threader engaged to the needle hold the thread between your two hands horizontally and slide the thread behind the needle starting from the bottom up until you feel it stop then pull the threader gently out toward the back of the machine. Sometimes it takes a few tries to get the hang of it
Jan 20, 2010 | Sewing Machines
Automatic needle threader on brother se-350
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Sewing Machines Logo
98 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
