Question about JVC Car Audio & Video
I am installing a jvc radio into my 1978 cj5. I have isolated from the radio 3 wires. Battery, accessory and ground. I know where the ground goes but wonder about the other two.
Posted by bill edge on
EmBalmU
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
The accessory wire needs to work with the key turning. the battery wire connects to the battery. if you have a volt meter it can be very easy to find your wire connections in the fuse box. find the ignition fuse in the box set your meter to volts dc take your black lead to a chassis ground and the red lead to one side of the ignition fuse turn your key to accessory and see if you get 14 volts if you do get it thats your connection. if not try the other side of the fuse.
Posted on Nov 28, 2019
5 Related Answers
storm88
  • 7 Answers
SOURCE: 1999 Grand Cherokee Radio Wiring Harness Diagram/Color Codes
Go to www.installdr.com and search through the diagrams in there, the site is easy to use, all you need is acrobat reader installed on your computer to use the site, it has a full explanation on every wire color and what it is
Posted on Aug 30, 2008
Anonymous
SOURCE: 1957 Ford car radio installation.
there are actually 4 wires on the right side 2 are speaker wires and the other 2 are the positive and negative connections . the black wire is positive supply and the green/red wire is negative earth . strange wiring !!
bcnu
fred
Posted on Sep 12, 2008
Anonymous
  • 61 Answers
SOURCE: dvdcar dvd player pioneer p 5000
if you are popping fuses you must ground all the black wires to metal in the car sounds like the ground is carrying a positive charge .......you must also check the 10amp radio fuse located in the panels of the car mostly located in-dash panel by the door ........hope i helped
Posted on Mar 04, 2009
jturcotte
Jeffrey Turcotte
  • 8984 Answers
SOURCE: Im installing a
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Posted on Aug 28, 2010
xxxxxx xxx
  • 5023 Answers
SOURCE: the red power wire and
The majority of these radios are FUJITSU TEN units and the socket wiring as this diagram (also fitted into Toyota)
http://elsegra.com/Car%20pinouts/TOYOTA_datoteke/image004.gif
Posted on Jan 30, 2011
How do you remove ignichtion switchfrom stering collem 1978 jeep cj5
should be a small pin hole in the face of the ignition switch itself, straighten out a paper clip and use it to push into this hole it will release the switch to come out, may have to have key in and turned to accessory position to let it come out
Install battery isolator
if it is just the one battery, put the isolator on the ground wire
if the ground wire is turned off by the isolator , there is no circuit
1helpful
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
2helpful
Radio and inside lights not working
Check your grounding, prob have used illumination line as ground, when lights switched on it goes to 12 volts and if connected to radio ground fuse will pop. Ground radio to chassis and isolate the wire you have used, replace fuse (probably blown) and should fix your problem.
I want to wire the kd-s640 to my boat. I need to know what wire by color (except black ground) goes where. Thanks. [email protected]
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
1helpful
4answers
JVC drains battery when OFF, puzzling
The problem is actually the wiring. Check the installation manual, I guarantee the "pro" installer took a shortcut.
There are two power wires (yellow & red +) and a ground wire (black -).
Now, black goes to chassis grounding point. Easy.
Yellow goes to a live terminal in the fuse block for constant 12V.
This retains the settings and clock etc.
Red goes to an ACCESSORY terminal in the fuse block (so key must be turned to at least ACC to allow it to be switched on).
But in the case of my car, the idiot who installed it ran the red wire directly to the + battery terminal. That's wrong, and will drain the battery.
Google for an installation manual, I'm certain your JVC head units will be the same procedure.
1helpful
2answers
My JVC KD-S25 will only turn on when I press the eject button, and then it shuts off in 5 seconds.
I just bought this stereo and installed it the other day. I had the same issue. Hook the Yellow power wire and the red accessory power wire to the same power source. That solved my problem.
1helpful
2answers
Installing a new car radio
if you have a wiring harness al the wires are color coded to match the after market radios colors. the yellow constant wire goes to 12 volt or battery wire. the accessory wire would be the red wire that is the switched 12 volts. the remote is for the factory amp or an aftermarket amp which turns on and off it would be the blue with white wire.
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
