Question about Home
I have a 19 266 Thermostat trim Shower/Safety valves shower. The valve is broke inside. It just turns with no change in temp. I removed the handle but can't remove the valve. Help.
Posted by Sam Kalil on
2 Related Answers
Anonymous
  • 49 Answers
SOURCE: grohe trim pressure balance valve
i looked at it and there might be a press in cap with a screw underneath where the grohe label is. there also may be a set screw around the shoulder of the handle where an allen hex wrench fits to losen its clamp on the stem. also.......some handles just snap on and just pull off with some tugging and wiggling them just right.
Posted on Jan 23, 2009
dragonsthatk
albert getty
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
Best to remove 2570 Cartridge.Also can tell why their cold water no hot water
Moen cartridges require a Moen puller tool. Your local hardware store will carry this. You may not be getting hot water because there's a safety tab located on the cartridge that is preset during initial installation as an anti-scalding safety feature, and that may have worn, broke, or have shifted during time. Hope this helps!
Dec 02, 2010 | Moen & Posi-Temp Single Handle Shower Or...
When i turn it on it is only warm at best. when i turn it all the way hot the water comes out in a trickle. all our other showers and sinks get hot water just fine. this is a single handle shower and does...
You will need to remove the old cartridge from inside the shower valve body and either refurbish it with new rubber seals and O rings or replace the cartridge altogether (preferable). It's not a complicated fix but the Posi Temp cartridge can be a bear to remove. Moen and Danco make special 'pullers' to make the cartridge removal go a little easier (sold at Lowes/HD and plumbing supply for anywhere between $15 and $35 but well worth it, IMO).
Oct 27, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
Replaced trim ring and handle, now hot is cold ,cold is hot
Remove the handle and turn the stem of the cartridge 180 degrees then put your handle back on.
Apr 27, 2010 | Moen & One Handle Tub & Shower Faucet
Sensitive Temp adjustment through shower.
Pull the trim off of the valve and you will see a 1 inch diameter flat screw, unscrew that and clean it out and try it again. If rinsing it doesn't work you may need to replace it. It is called a balancing caulk.
Apr 24, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Jan 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Single handle shower valve.. can't get any hot
factory set is usally cold for safety. remove handle, then remove cover. you will see the mechanism, bunch of plastic teeth, set it up in the middle, then try it, repeat process till you get desired temp
Aug 01, 2009 | Home
Shower Handle broke off assembly
pull the holding clip and then pull the valve out. you might have to grab it with channel locks or pliers because sometimes they are hard to pull out
Jun 24, 2009 | Home
Home Logo
125 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
