Question about Nixon Watches
Set time on nixon camden chrono watch - Nixon Watches
6ya staff
SOURCE:
Anonymous
SOURCE: luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Posted on Sep 12, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Posted on Feb 10, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How do I set the time on my Nixon Fidelity watch?
Find SKAGEN watch manuals here in my TIPS. I submitted few days ago.
Posted on Feb 07, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How do you set the time to the Nixon 51-30 watch.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Nixon watch manuals. To stop the crown to come off it must be screwed and secured onto stem. If you are not sure how to do that, visit your nearest watch repair shop and they will do it for you. Rate me, please.
Posted on Feb 26, 2010
David Tolond
  • 2501 Answers
SOURCE: I need a manual for a Festina, Chrono Bike, watch
Festina do not have much of a web site at present but if you go to "www.festinausa.com/", you will see a customer service address who may be able to help you.
Posted on Mar 12, 2010
Hi - i need a manual for a nixon The Housing - or how dot I set the time and tide on it
Hi here is the link for all of the nixon manuals
http://www.nixon.com/manuals/index3.html
Kind regards
Sep 12, 2014 | Nixon The Housing Watch
The chrono when you press to reset it dosent go to the 12
pull the crown out to second position press start button till it goes to 12 push crow back in,,,,,,,
Apr 08, 2013 | Nixon 51 30 Pu Watch
Can get the time to start
The watch is a chronograph. If the time hands are not working, minutes and hours, you probably need a new battery. If they are working and it is the chronograph(stopwatch) hands you can't get going then you need to push the buttons that control the chronograph.
Oct 16, 2012 | Nixon The 42-20 Chrono Watch All Black One...
I need extra links for the Nixon 42-20 crystal bezel chrono. The watch is too small.
I have looked at the Nixon site and it says that spare links are provided in the bottom of the box, see below.
Do you still have the presentation box?
"The compartment at the bottom rear of the watch stand can be opened and closed, and it contains the user manual and extra links and pins."
Apr 07, 2011 | Nixon Watches
My new nixon 42 20 when i reset the chrono the second hand doesnt go back to zero it goes to 16 seconds past how do i sort this problem its annoying !
  • Undo & pull the crown all the way out,then
  • undo the adjuster button (the one underneath the crown)
  • push the stop/start adjust button one push at a time and it will move in slight increments,keep going till you get the second hand on the 12 mark
  • then push the top adjuster and it will go back to the 12 mark.
  • Push the crown in and wind your adjusting buttons up and you have finished
Aug 20, 2010 | Nixon 4220 PU Chrono Watch Black
The hour hand on my chrono will not reset to 0 when the min and second hand do
Pull the crown out as if to set the time then press the chrono pusher,this will advance the chrono hand.
Aug 16, 2010 | Nixon 51 30 Pu Watch
Watches Logo
26 people viewed this question
Top Nixon Watches Experts
Janelle Schoonover
Janelle Schoonover
rhodesworks
ray gallant
ray gallant
Are you a Nixon Watch Expert? Answer questions, earn points and help others
