Tv not receiving signal. What do I do? I get the messag on the screen standby for signal but nothing happens
Posted by Phyllis Coffin on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 57,306 Answers
Could be a poor antenna or cable connection
Posted on Aug 16, 2020
2 Related Answers
Anonymous
  • 47 Answers
SOURCE: initial hdmi tv, no signal received
If you are trying to get 'off the air' signals then you must scan for the new digital channels in your reception area (this info should be in your owners manual). If scanning doesn't find any signals, you might have to add a VHF/UHF line amplifier(s) between your antenna and the TV set or improve your outside antenna or the cable leading from it to your set. You might have to resort to subscribing to HD cable or satellite TV.
Posted on Jun 22, 2009
raycalo
Ray Calo
  • 358 Answers
SOURCE: Dish Network "No Signal" Message on Screen..Standby Mode
austinbrooke,
I saw your post and I'm wondering if you are still having problems getting a picture on your TV. Is it TV 1 or TV 2? What type TV is connected? If it's a HD TV, you will need to go through your input or source list on the TV to find your picture on TV 1. TV 2 is generally on either channel 60 or 73. I hope this helps.
Ray Calo
DISH Network
Posted on Jan 08, 2011
Philips tv black image
From the stand point of cost to repair this I would just buy new.
Feb 02, 2017 | Philips Televison & Video
I turned dish on and all I get is snow
Check the input cable to dish box for firmness and the orientation of the dish.
Feb 16, 2015 | DISH Network Televison & Video
Not receiving signal
Do you have all connections hand tight? Are you getting an error message on the screen? What type of cable are you using to connect to the TV, Coax or RCA?
If you're not getting an error message what type of cable are you using? If it's a Coax Cable, you will want to make sure the TV is on channel 3 or 4. If you're using an RCA Cable, you will need to check the Input channel.
Thanks
Apr 04, 2014 | DISH Network DTVPal DVR by
The tv does not stay on when turned on goes off right away
This TV decided there is nothing of value to watch << Just kidding, could not resist...
Is there any message? If you do not have a signal to the port that the TV is set to, many will go into standby mode, but there is a message. This is a bigger problem with Blu Ray, as the machine takes forever to start up and there is no output signal during the start up, so that would cause the TV to go into standby mode (shut down).
Jul 23, 2011 | Philips 42PFL5332D 42 in. LCD Television
austinbrooke,
Ray Calo
DISH Network
May 31, 2010 | DISH Network 322 DTV Receiver
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Insignia 37" goes into standby mode
I am experimenting with Insignia's and there is a feature whereby if a signal is not detected the TV will switch to standby mode (in about 10 - 15 minutes). It's documented as a tiny "note" in the manual under "Understanding the basics - Turning TV on or off"
I don't know if the TV resumes when the signal is restored or if you need to power on manually.
You are probably experiencing a glitch with the signal or the TV thinking the signal is not there. Are you watching a clear picture when this happens? I would first check to see if the signal is too weak (like using a signal booster). If that is not the case, it's probably the TV acting up.
I hope this helps.
Is this
May 26, 2009 | Insignia 37" LCD Flat-Panel HDTV
Sony tv problem
If you are connecting the dish receiver to the standard antenna jack (F connector) on the TV, then the TV must be in TV mode and tuned to channel 3. If you accidently change to another channel then you will get the "no signal" message. If this is the case then simply put the TV back on channel 3. If you are using the RCA jacks (red, white yellow) to connect the dish receiver to the TV, then the TV must be in the VIDEO mode to work properly. If you accidently put the TV in the TV mode, you will get the "no signal" message. If this is the case then simply press the TV/VIDEO button.
Sep 18, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
