Question about Juicers
How do I dismantle the driver of a milex juicer it has 3 adjustable knobs to push in. I have tried but it does not release
Posted by hennie hanekom on
2 Related Answers
Anonymous
SOURCE: How to dismantle my juicer?
Simply turn the top counter clockwise like you would open a jar.
Posted on Nov 13, 2007
ray gallant
  • 68633 Answers
SOURCE: please help, i need help cleaning my milex juicer
perhaps they have similar item Juicer Instruction Manuals and Instructions available here
Posted on Mar 20, 2015
How do i dismantle the juicer to clean it ?
would help to know what juicer model is......kenmore???
Jul 02, 2016 | Juicers
I have a Homemaker HY5028. It's hard to clean it without taking the sieve out. Is it possible to take the sieve out without damaging it?
You need to use a knife or something to push down the small black release button then it will lift straight off. I got my daughter to push down the button as i lifted.
Aug 23, 2011 | Juicers
I HAVE A JUICER MODEL #JE95XL ITS ONE YEAR OLD,I
Go to Lowes, to the cabinet knob dept. Get a cabinet knob that matchs the holes in blade. You can always bend the screw a tiny bit if needed to fit. Put the screws into cabinet knob, and tighten. Cut the heads off and you are ready to go. They have a knob that is stainless steel, just a flat piece across the top, an 2 straight pieces that go down. I think it was $2.97. It gives good grip, and takes the blade right off.
Aug 21, 2009 | Breville JE95XL Juicer
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Rotel Juicer
Once the handle has been pushed aside, it is easy to dismantle down to the perforated bowl. This is a push fir onto the black plastic boss and should wriggle off quite easily for cleaning.
Jun 03, 2008 | Juicers
Juice extractor - dismantling after use
Look at the dismantling and cleaning procedure in JE95XL Juice Fountain Plus user manual on Page 14 and 15. Procedure is the same with JE900.
http://www.breville.ca/site/EN/products/je95xl/je95xl_manual.pdf
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
Apr 01, 2008 | Juicers
Unable to remove the seive from the machine
We just solved that puzzle! Press down on the cuter disc with your fingers, and while pressing, turn that disc counter clockwise. It may be a little reluctant to turn. It will loosen, and you can spin it easily. This will release the sieve and allow you to take the assembly off for cleaning.
Sep 11, 2007 | Jack Lalanne Power Juicer 250 Watts
Aug 10, 2007 | Acme 5001 Supreme Juicerator Juice...
Juicers Logo
126 people viewed this question
Top Juicers Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Juicer Expert? Answer questions, earn points and help others
