Refrigerators Logo
A
Anonymous Posted on Nov 05, 2019
If I do not change my filter in my fridge is that the cause that my ice maker do not work. I see water in the hose but no fabric of the ice in the ice maker
Jorgie Navito
Level 3:
Master:
  • Refrigerators Master 357 Answers
  • Posted on Mar 12, 2020
Jorgie Navito
Level 3:
Master:
Answers
357
Questions
0
Helped
108867
Points
2245
No filter would normally effect the taste of the water and ice.
ICE MAKER not making ice
Inspect Water fill tube,Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valvefor any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valveis operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE:Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will benecessary to replace the valve(the filter is not removable on most inlet valves).Test thewaterinletvalve for continuity using amultImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set themultitesterto the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. Themultitestershould display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating).The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Alsonote that your home's water pressure may not be strong enough to serve an ice maker.)
If you have aheat releaseor modularice maker itwill have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points"T" and "H" to initiate a "test harvest".On other ice makers jumper at pointsN & M(neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis.This is a live voltage testand should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat ina componentice maker:
The thermostat is located near the bottomofthesupport box. The thermostat is connected by two or threewires.Labelthe wire placement before disconnecting them. Removethethermostatby loosening the clamp, by pushing back theretainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusingamultitestersetto the ohms setting X1. Start by testing the thermostatwhenithas come up to room temperature (about 20 minutes after removingit from the freezer).
If the thermostat has two wirestouch one probe to each wire. You should get a reading ofinfinity.Chillthe thermostat in the freezer for about twenty minutesandretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires,number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinationsshould yield a reading of infinity and one should yield areadingofzero. Now chill the thermostat in the freezer for about twentyminutes and retest. The combination that had a zero reading before,should now have a reading of infinity. One of the two other combinationsshould now yield a zeroreading.Ifthe thermostat fails this test,it should be replaced.
Testing amodular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicateinfiinity(no continuity).If the thermostat does not pass both tests, it should be replaced.
https://www.youtube.com/watch?v=BFh8aa7asvw
https://www.youtube.com/watch?v=fPeZ29XdX5U
http://www.appliancerepair.net/refrigerator-repair-1.html
God is the reason I give you free advice so God is good!
If I do not change my filter in my fridge is that  - ice-maker-how-it-works-undefined-undefined-0.jpg
icemakerfilIf I do not change my filter in my fridge is that  - icemaker start times cycle manually-undefined-undefined-9.jpg
	 <img loading=
5 Related Answers
Anonymous
  • 1073 Answers
  • Posted on Apr 30, 2008
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
shaggyrat
Christophe Thompson
  • 1224 Answers
  • Posted on May 15, 2008
SOURCE: Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
Anonymous
  • Posted on Dec 19, 2008
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Anonymous
  • 10865 Answers
  • Posted on May 30, 2009
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Anonymous
  • 3 Answers
  • Posted on Oct 18, 2010
SOURCE: GE Monogram fridge is not dispensing water. Ice
Check your QuickChill damper in the feature pan. If it fails/hangs in the open position, you get excess Freezer air in the pan and in the vicinity of your water tank, which can freeze it solid
I have an Amana refrigerator ABB2222FEW, freezer on the bottom. There is a smell coming from the fans flowing into the fridge. Food has been removed, fridge cleaned, still smells. Can you help?
FOUL TASTE OR SMELL IN ICE OR WATER FROM FRIDGE
Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently. Lastly a clogged drain line can cause a foul smell and get into the ice and water as we,,.
I have a 1 and a half month old Danby all-fridge, and there is a smell like rotting flesh coming from it but not smell inside the fridge. ??if I need to find the water drip tray where is that located?
water drip tray is usually located under on on top the compressor? at bottom of fridge can pull out at front or back
My frigidaire refrigerator has terrible chemical smell
Refrigeration System Basics Chapter 1
1helpful
Water out is very salty(?)
1helpful
2answers
Bad tasting water and ice from fridge and kitchen tap...
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
2answers
what filter? drying filter? Water filter? Dust Filter?
Filtered Water tastes "off"
Could be something foreign in the water line on the fridge side...or somewhere in the ice maker/ water dispenser inside the fridge......when it tastes stale....maybe there is something maybe mold or something that is part of the plastic ????
I usually add an in-line filter to my water line before it reaches the fridge so that 99% of the elements are trapped before it gets to the fridge. My original filter is still good. Maybe someone needs to inspect the ice maker with a a bright light and an inspection mirror to see if there is any thing that looks suspicious....this is only a suggestion but leaving the line disconnected for so long could even cause something like a small insect to crawl inside the line...
2helpful
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
