WMA50P unable to open door when any cycle ends.
Machine indicating cycle end and door locked but still giving occasional pulses, with selector switched off door still locked.
Posted by Brian Herd on
Tom Chichester
    Top Expert:
  • Washing Mach... Master
  • 57,285 Answers
This could be a cycle timer fault, especially because it pulses after the cycle indicates complete.
Posted on Aug 17, 2020
5 Related Answers
wagdom
keith wagstaff
  • 64 Answers
SOURCE: Door is locked! Won't open! Laundry is stuck inside!
If the water has not completely emptied, this wont allow the door to open. Check by lowering the outlet hose into a bowl. If a fair amount of water comes the problem is likely to be a pump blockage
Posted on Oct 26, 2007
Anonymous
  • 148 Answers
SOURCE: Kenmore dishwasher locks. after cycle, can't open door
bad solenoid or controller
Posted on Dec 21, 2007
francis rivero
  • 958 Answers
SOURCE: Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Posted on Aug 30, 2008
Anonymous
  • 135 Answers
SOURCE: Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Posted on Nov 11, 2008
Anonymous
SOURCE: Hotpoint Aquarius wf320 door won't open.
what you need to do is say 'abracadabra' 3 times , then swear allegience to the queen always remembering Glasgow Rangers are the best ..hee hee
Posted on May 04, 2009
Why cat I open door at end of wash cycle
http://www.whitegoodshelp.co.uk/washing-machine-door-will-not-open/
Mar 14, 2016 | Hotpoint Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
I can't open my washing machine please help
It locks during certain cycles. Try turning the selector switch to end of cycle and try opening. If it's stopped mid cycle, try unplugging it for a minute or two and plug it back in.
Nov 19, 2012 | Washing Machines
I have towels in the machine and the cycle stops at spin. How do I open (unlock) the door to get the towels out as I think they are imbalancing the machine.
This is a common problem, often associated with the machine aborting due to an unbalanced load. You will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Jul 19, 2011 | Washing Machines
The front loader door won't open after the cycle what can I do
1. If it is an old machine with a mechanicvcal selector, make sure the selector is set to the end of a program.
2. Unplug the macine from the mains and leave 20 minutes. That will ensure it has reset. You should be able to open the door.
Jul 01, 2011 | LG Washing Machines
Whirlpool duet washer, door locked light on door open no other lights on unable to set control
The control can be locked to keep the buttons from activating during external cleaning or to help from small children starting the machine.
To activate or deactivate press and hold the "end of cycle signal" button for 3 seconds.
Jun 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Turning the dial to any wash cycle clicks 3 times and end button flashes, won't wash at all.
You have not indicated a make and model, but this sounds like the door lock is faulty.
To test this theory, leave the door completely open and start a cycle, the w/m should have the same clicks and flashes, which more than likely is it telling you that you are trying to start a cycle with the door open. The w/m can not differentiate between a faulty door interlock and the door not being closed.
If nothing else this should give you a starting point for a diagnosis.
If you need to repost or comment please included the make and model number, on most machines this will be on the inner door frame.
Best of luck.
Jul 19, 2010 | Washing Machines
Won't spin
Close the door firmly and make sure the machine is turned on. Press and hold the Chime and Extra Rinse keys until the control beeps to enter Service Mode. All indicator lights will turn off except the "Door Lock' indicator signifying the door is locked.
Press the Rinse & Spin key then rotate the cycle selector knob in either direction to display the most recent error codes if there's any. Press and hold the cycle selector to display the number of cycles since the error occurred. List down at least five most recent codes and post it here for us to determine what the problem could be. Press and hold the Delay and Chime keys for three seconds to clear the list. Press the Rinse & Spin key again to exit diagnostic codes list.
Press the Spin Only key while in the Service Mode to begin the Board Input Test. Set the rotary cycle selector to Super Wash then press it to display the position of the door switch. "OP" will be displayed if the door switch is open or "CL" if it is close. Replace the door lock/switch assembly (part #34001265) when "OP" is displayed even the door is close. Press the Spin Only key again to exit the Board Input Test.
Press the Spin Speed key while in the Service Mode to begin the Board Output Test. If water is present in the tub, set the rotary cycle selector to Quick Wash then press it to turn on the drain pump and drain the water. Press the rotary cycle selector again when the water is fully drained to turn off the drain pump.
Press the Delay button to turn on the motor and the Delay indicator light. The machine should tumble clockwise then counterclockwise with 5 second durations each and 2 second intervals. Press the Spin Speed key again to exit the Board Output Test.
Press Off or press and hold Chime and Extra Rinse keys for three seconds to exit Service Mode. Unplugging the washer will also exit Service Mode.
Perform the tests above and let us know the results for us to determine the cause of the problem or the necessary action to undertake and give you the specific and detailed instructions on how to fix it.
Mar 03, 2010 | Maytag Neptune MAH9700 Front Load Washer
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
