Why does my monitor bleep - Computers & Internet
  • Not Me
    Not Me Nov 05, 2019
    Hi Avril hughes, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Wha t make and model? When does if beep? Does it do anything else (lights,picture, backlight only and dark screen, etc?)
How to repair a52f powers no bleep blank screen usb not working?
it seems that the gpu has burned out send it back to be repaired or get another
Aug 17, 2014 | ASUS Computers & Internet
What should i do my desktop goes on bleeping after I changed battery?
Bleeping? Sure it's not a Sheep?
OH, I'M JUST KIDDING!
The beeps you hear are BIOS Beep Codes. The computers way of telling you something is wrong, and an area to look into for it.
http://www.5starsupport.com/info/beep_codes.htm
I hope you had the computer unplugged, and FOLLOWED Anti-Static Precautions.
If so you probably just knocked the Ram Memory loose.
Remove all Ram Memory module/s ('Stick'), and then reinstall.
It is the only way you will be assured they are installed tightly, and correctly. Visual inspection will NOT do.
[ Positive ( + ) side of battery goes UP ]
http://www.dell.com/support/troubleshooting/us/en/19/Product/inspiron-530s
Regards,
joecoolvette
Nov 25, 2012 | Dell Inspiron 530s Desktop Computer...
Monitor Blank screen,
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
May 02, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
When switching on PB not loading and is realising loud bleep
yes the beep pattern. btw , try checking your memory if you have 2 of them on try removing the other 1 then turn on pc. n do it vice versa. if
Jan 22, 2009 | Acer Aspireā„¢ T180 PC Desktop
My monitor just went "bleep" and blacked out.
Turn off the computer then turn back on. Try plugging in a different monitor to see if its a video card issue. Sounds like your monitor is toast though.
Jan 18, 2009 | Computers & Internet
CPU bleeping constantly.
Yes that means the computer has failed POST. So yes, something has come loose or has got damaged.
"POST" is an acronym for Power On Self-Test. The POST process checks the basic system functions before attempting to load an operating system. It checks RAM, processor, drives, system interface, etc. If POST fails, the system will normally halt and may produce a series of beeps from the computer speaker which can help indicate the cause of the problem.
Jan 17, 2009 | Computers & Internet
Switches on & bleeps
try to check the cable connection between the monitor and the tower. what is the color of the LED light on the monitor?
Oct 27, 2008 | Dell Dimension 3100 PC Desktop
Comp won't boot after installing new ram. possible motherboard problem?
try emoveing both sticks and blowing into the ram slots then replace 1 stick at a time. if this dose not work try checking all the cables to make sure nothing got knocked out of place when you installed the memory in the first place. (bleeping sounds can mean a lot of diffrent things if the problem carrys on count the bleeps and look on google to see what that number of bleeps means for your motherboard) hope this helps
Sep 12, 2008 | AOpen XC Cube EX661L (95EZ619321) Barebone
New Mobo & Processor but no Bleeps etc
Could be the power supply is not strong enough to power the system. Replace the power supply with one that is between 350 - 450 watts. This should provide ample power to the system.
Aug 05, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
Ekse
Marvin
Marvin
