Question about Lands Phones
SOURCE: remote call forwarding/message retrieval; record voice mail message
i found my solution on the AT&T website.
thanks anyway.
Posted on Apr 01, 2008
SOURCE: RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Posted on Jul 29, 2008
SOURCE: all incoming calls go straight to voice mail
Just go to call settings and then call divert. check settings. Maybe all calls are diverted to voice mails. Cancell all diverts. Then you are done.
Posted on Jan 21, 2009
SOURCE: how do i get my voice mail box # so i can recieve
Your voicemail number is the number of your cellphone. When the voice mail picks up, you must press # on your cellphone, and then you will be prompted to enter the security code, which on default, is 9999 or 0000 or 1234. Hope this helped!
Posted on Jul 23, 2009
SOURCE: Inter-Tel Axxes phone outside calls don't go to voice mail
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
Hope this helps someone?
vandata1
Posted on Mar 11, 2010
Sep 05, 2018 | Qlink Motorcycles
on Mar 07, 2011 | Cell Phones
Dec 02, 2014 | LG Remarq LN240
Aug 31, 2011 | Incase iPhone 3 & 3GS Perforated Snap Case...
Apr 25, 2009 | Dual Electronics CECT P168 Cellular Phone
Sep 11, 2008 | Panasonic KX-T7630 Corded Phone
Feb 21, 2008 | LG VX5300 Cellular Phone
Jan 25, 2008 | Vtech 5.8GHz Analog Cordless Phone
Oct 07, 2007 | GE 25952 Cordless Phone
103 people viewed this question
