Lifesmart bahama 350dx shows hl and will not run, i have unpluged and reset but shows hl everytime
Posted by Robert Simon on
Life smart heater....does it have a reset button or something
Hello, Karen -
I have found several user manuals for Lifesmart heaters online and have looked through them.
None of the manuals I looked through mention reset buttons.
You have not stated the model number for your Lifesmart heater. If you choose Comment and type the model number in the Comment box, perhaps I can find the right manual for your heater and give you the link to download a copy of the manual.
Is your problem that while using your heater is suddenly turns off? If so . . . following is the information I found in the Lifesmart heater manuals (several different models:
(Quote)
Overheat Safety Feature
This heater is equipped with an overheat safety feature. When the internal components of the heater reach
a certain temperature that could cause overheating or possible ?re, the heater will automatically shut of
(End quote)
If that is the case with your heater, you will need to let it cool down before restarting it. You will need to make sure the Power button is turned to Off and then unplug the heater to allow it to cool down.
If you indicate the model of your heater, I will try to find the right user manual for you to download.
Best wishes.
Oct 16, 2018 | Heating & Cooling
Lifesmart heater wont turn on
Here is a troubleshooting video. Hope it is useful
Jan 08, 2015 | Lifesmart LS-PP1800-6WCH 1500W Plus...
My lifesmart infrared heater cuts of when on ecno
Its eco mode aka turns off and on to save energy.
Dec 23, 2013 | Lasko 5132 Ceramic Compact Heater
Heater runs 1 cycle then turns off
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Oct 18, 2013 | Lifesmart Renew Infrared Quartz Heater...
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
How do i reset my printer? it always shows a LOW TONER, even though it was newly refilled. There is also a vertical line that appears on the side everytime I copy something (photocopy).
Step 1: Toner Reset Menu for Brother HL 3040CN and HL 3070CW
1. Open Cover where you can access toner cartridges
2. Press CANCEL & SECURE PRINT buttons at the same time and you'll see
the toner menus on the screen
3. Press + or - to navigate through to the toners you need to reset.
Note that each toner has 2 entries here, reset them both (STD means Standard, STR means Starter)
4. The OK button will reset of the toners.
Apr 18, 2011 | Brother DCP 9010CN - multifunction ( /...
Reset all functions and hands
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TOMMY BAHAMA watch manuals.Rate me, please
Mar 21, 2010 | Tommy Bahama TB1089 Watch for Men
Loud hum from back of tv when first turned on
i liv in the bahamas and they dontsell zcards can i hav 1
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
66 people viewed this question
jasbo
jasbo
Marvin
Marvin
