Question about Keurig Coffee Makers & Espresso Machines
Keurig B60 when I power it on, it leaks water out
Posted by Anwar Mirza on
Tom Chichester
    Top Expert:
  • Keurig Master
  • 57,296 Answers
Your Keurig needs to be replaced.
Posted on Aug 18, 2020
5 Related Answers
Joe Hogan
  • 10865 Answers
SOURCE: The brewcover on my Keurig B60 broke. Both screw
Hi. go to keurig.com/parts and order what u need. J.
Posted on Jul 25, 2010
Anonymous
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
Anonymous
  • 3 Answers
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Posted on Dec 31, 2010
biotin80
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: My Keurig B60 will not power on, worked fine this
The most common problem is this category is the no power, or Keurig not turning on, problem. When this happens it is usually because of the failure of the transformer inside the machine. The low voltage transformer is located underneath one of the solenoid valve in most of the machines. The hoses to this valve and/or the valve will leak a bit and drop water down onto the transformer. Electrical components and water do not play well together. The transformer will soon go bad when it gets water on it. For that matter, many brewing problems are caused by the air pump getting wet from the same leaking point also. The air pump can sometimes be fixed, but the transformer is not even available to be bought as a replacement part, and there is no fixing them.
Posted on Oct 11, 2011
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
My Keurig B60 stopped working - I plug it in and nothing happens. Prior to this, it was leaking and lights were blinking
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 17, 2011 | Keurig B60 Coffee Maker
Replace thermal fuse in a keurig b60 (where is it located)?
heatman101
Sep 12, 2011 | Keurig B60 Coffee Maker
My Keurig B60 won't turn on. Tried different plugs. What now?
heatman101
Sep 07, 2011 | Keurig B60 Coffee Maker
Keurig B60 will not turn on anymore. Was working for months with no problems.
heatman101
Aug 29, 2011 | Keurig B60 Coffee Maker
My b60 keurig keeps scrolling in menu mode wont brew coffee let me know if there is a fix
heatman101
Aug 21, 2011 | Keurig B60 Coffee Maker
Keurig model b60...wont power on, dont know where the fuse is
heatman101
Aug 15, 2011 | Keurig B60 Coffee Maker
The machine won't turn on at all. Tried t in several functioning outlets and it won't power up. Only 6 months old. Keurig B60
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
My Keurig B60 will not work.
heatman101
Aug 07, 2011 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
138 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Bruce Showalter
Vincent G
Vincent G
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
