SOURCE: 2000 mazda millinia tilt stopped working
had the same problem. went to change the drive motor for it but found that there are drive gears in the steering column that were broke. replaced with a used one from junk yard, around $600
SOURCE: my 1978 140 evinrude electric trim tilt motor
First make sure you are not in transit mode. Some outboards have a lever which keeps the motor tilted for trailering. You should have a fuse for the tilt motor, check that. If the pump is turning and it sounds like it is whining you are pushing air and either lost your hydraulic fluid or have an air bubble in the system. Check your fluid reservoir.
SOURCE: 140hp johnson seahorse tilt will raise the motor
it needs fluid added. had a 70 johnson do the same, I saw no leaks but it was low on fluid, put some in and have had noproblems yet.
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
SOURCE: lower unit removal for johnson 225 hp outboard
Yes
Testimonial: "ill give a go in the morning thanks again"
