Question about Measuring Tools & Sensors
Instructions for rapitest stud finder - Measuring Tools & Sensors
Posted by Aileen Simpson on
2 Related Answers
Anonymous
  • 57 Answers
SOURCE: online manual for Rapitest Wps 115 Wire/Pipe & Stud Detector
go to the support center for the maunfacture site
Posted on Oct 13, 2009
Colin
  • 1584 Answers
SOURCE: I have a Rapitest pipe/wire and stud finder but
If its like my one (Different brand) you simply switch on and adjust fine control till the lamp just comes on then turn opposite way till lamp just extinguishes, Make suer the unit in pressed onto the wall.
Posted on Jan 26, 2010
Testimonial: " You only answered part of the question."
Floureon 3in1 stud finder instructions
Put it on the wall, turn the sensitivity know until it beeps, turn it back a fraction until the beep stops. Run the device across the wall. If it does'nt beep, you were on a stud the first time!
Floureon 3in1 stud finder instructions Google Search
Sep 24, 2017 | Measuring Tools & Sensors
Stanley stud finder AC sensor continually beeps on 10mm plasterboard wall
Most stud finders have a sensitivity adjustment that should be carefully adjusted per instruction manual before use.
Failure to do this results in erroneous indications.
If you have adjusted exactly per the instructions with the same result the unit is probably faulty.
Sep 22, 2017 | Stanley Measuring Tools & Sensors
Rapitest Pipe stud and wire tetecor instruction
no idea never used one to be honest but i would imagine that passing it over a cable it would emit a noise ??
Feb 02, 2012 | Cars & Trucks
I can't find my user guide, What settings do I use for stud finder?
Hello. The instructions can vary from model to model. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
http://www.irwin.com/support-services/product-manuals
If this answer has helped, please rate it a four-thumbs up. Thank You.
Mar 27, 2011 | Strait-Line Intersect Laser Level With...
How do i find a stud with the stud finder
Aug 18, 2010 | Strait-Line Intersect Laser Level With...
How do you know when the strait line laser level and stud finder is on a stud
Hello. The instructions can vary from model to model, but most have a green indicator light that lights up when the unit detects a stud. There is a section in the manual (for most models) that will show/inform of the unit's individual method. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
Jun 18, 2010 | Strait-Line Intersect Laser Level With...
I have a Rapitest pipe/wire and stud finder but have lost instructions.Can you please help. What is the significance of the circle and the triangle settings?
Jan 26, 2010 | Hand Tools
Online manual for Rapitest Wps 115 Wire/Pipe & Stud Detector
Oct 13, 2009 | Hand Tools
Lost instructions to Ryobi EMTP006 stud finder, I don't remember how to use.
1st press and hold the yellow button on the side until " on " is displayed. THEN after 3 seconds unit calbrated and ready to scan. bar graph and audio indicates edge.
sonic tape
just press read and it will read up to 50ft
"x" button gives area and volume
" " for addiction of length
Jul 13, 2009 | Ryobi WallTech Stud Finder Stud Finders
Measuring Tools & Sensors Logo
129 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
