I have problem on Dinamap Procare 300...when I switch on this machine ...the display show 930 error....how to solve it?
Posted by Farihin Fauzi on
1 Related Answer
fjmurdock
Fred Murdock
  • 83 Answers
SOURCE: Dinamap ProCare 300 error 'E13' displayed.
E13 indicates the battery is too low. The reason this occurs when you press 'inflate" is due to the battery being low and the inflation pump requiring more power to start the process. Make sure your green charge light is illuminated when plugged into AC (most likely it isn't). Check your power connections first: power cord to brick connection and barrel connector to Dinamap connection. If you pressed those in and still no charge light, replace the power cord, if still unsuccessful you'll have to buy a new power brick.
Posted on Dec 31, 2010
Can I get a temperature replacement probe ?
do a search through google.com for make /model and replacement parts
Jul 24, 2014 | General Electric Dinamap ProCare Series...
Pnet nibp fatal error
Hello, Two of my pro 300 V2 monitor display "Pnet nibp: module in fatal state (21015400)". Is it a programmed failure? What solution for the remeters in function? Thanking you in advance F. Bonnnin [email protected]
Jan 15, 2013 | GE Dinamap Pro 300 Monitor
My dinamap is showing error 950 when i hit the inflate start button. what is wrong?
HI From a Tech Guy,
Your issue is caused by motor over current.
Check the pump motor assembly under the foam cover.
remove torx screw on top.remove cover that has two nipples.
check inside mesh filter/ dust filter. if black is dust.
spray contact cleaner and blow with air. let dry.becareful not to use slovents may damage blue mushroom check valve.reassemble all.test should be ok.
hope it helps
cheers
Mar 12, 2012 | General Electric Dinamap ProCare Series...
What exactly does the MAP/cuff mean or measure?
Basically, the ProCare Series Monitor, is used in a hospital setting, on patients being transported from surgery, tests, ER, etc. back to their rooms. It's monitors their heart rate, blood pressure, breathing & pulse rate, as well as acting as a portable EKG machine. It alerts the transporter of any significant changes in the patient's condition, that would require immediate action, to save the patient's life. It records & stores all that data, for later review, if necessary.
Hope this helped you.
Jun 23, 2011 | General Electric Dinamap ProCare Series...
I keep getting an error code E83 Timeout:Inflation. I need to be checking my sons BP. Is there a trouble shooting i can perform? What do i do?
How old is the cuff? If it has written on it "single use" and you've been using it a while you may have microleaks which means you need a new cuff. Also, check the hose for holes (usually found where the hose splits and connects to the cuff). Last, check the Dinamap to hose connector are the black orings still on the connecting posts?
Critikon/Ge utilizes the oscillitory method for determining NIBP. In other words, it pressurizes the cuff, stabilizes, decreases pressure slightly, stabilizes, etc. so a leak in the cuff or hose won't allow the pressure to stabilize resulting in an E83 error.
Nov 04, 2010 | General Electric Dinamap ProCare Series...
My dinamap is giving me E13 msg. and I have tried replacing cuff, hose and checked all connecters. I have 3 units so have tried the same connectors and hose with cuff on another unit and it works fine....
E13 indicates not enough battery power. Does this error come on when plugged into AC? If so, please check the front of the unit to see if the green charging light is on (seen under mmHG), I bet you it's not illuminated. Check your power cord to power brick connection and the barrell connector to Dinamap connection (one of them is probably loose). If they are seated fine yet no indicator is lit, replace the power cord and if that doesn't solve it then order a new power brick.
Oct 21, 2010 | General Electric Dinamap ProCare Series...
Adjust time on a procare 400 dinamap
GE Procare 400 DPC-420N Unit turned off. Hold down Menu button while pressing the On button. Press Menu button several times until see a display to the left of the ?min? on the display area. Use + and ? to set time.
Feb 24, 2010 | General Electric Dinamap ProCare Series...
High reading on everyone using aDinamap GE Pro Care 300
Sometimes if the person starts moving his arm around or bending the arm in which the blood pressure is being taken, the high error will come on. The only solution that I know of is to hae a qualified person evaluate it.
Jan 28, 2010 | General Electric Dinamap ProCare Series...
Apr 07, 2009 | General Electric Dinamap ProCare Series...
Not reading of spo2
could be a bad preamp cable (the cable that goes from the machine to the actual sensor), bad sensor or you could be using the wrong cable/sensor for your machine. Even if all the pint line up for the connecters it may still fail. If you give me the serial number for your system and tell me if it is Masimo or Nellcor I can provide the right part numbers for the correct cable. At least you will have that as a starting point.
Feb 26, 2009 | General Electric Dinamap ProCare Series...
jasbo
jasbo
Marvin
Marvin
