Question about Lands Phones
Got a button mobicell phone not ringing on incoming call missing my calls what to do
Posted by Mary Van Ryneveld on
Bobbie Sanders
You can easily find water coolers and other Home Appliances in Pakistan online at affordable prices. These wonderful appliances ensure that you're never without a supply of cool water to refresh yourself with. They have long since been a staple part of many office setups, but they can also be a great idea for your home or study.
Drinking more water is something a great many of us should really be doing (I know I should), and a fresh supply of cold water helps promote a healthy lifestyle while working or simply spending time around the house. The ease of use of these useful and attractive appliances can help you drink a good deal more water, which helps you maintain a healthy diet and a clean respiratory system.
One good thing right now is that these marvelous devices are available at lower prices at present. There are many special offers to take advantage of online, meaning that it is easy to find one of these coolers at a price to suit your own budget. There are water coolers from all of the big names in home appliances, including Igloo, Enviro appliances price, Haier, and many more.
A well-made cooler is a wonderful addition to the home or office and can aid productivity while keeping thirsts quenched. Check out some of the water cooler reviews online and you can easily find one to suit your needs. Discount water coolers are also a great idea for staff rooms in workplace canteens and anywhere that a cold drink is required.
Jochaho.pk for home improvement. Getting the ideal home lifestyle you want can be helped along greatly by checking out more of the best microwave oven models available online at affordable prices!
Posted on Jul 04, 2020
5 Related Answers
sandrew
andrew pester
  • 2961 Answers
SOURCE: Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Posted on Aug 07, 2007
Anonymous
  • 52 Answers
SOURCE: my phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Posted on Jul 17, 2008
Anonymous
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
Anonymous
SOURCE: phone doesn't ring for an incoming call
Hi Sheetal hear My HTC touch windows 6.1 has a problem.When someone is tryin to cal me they hav my phone ringing in their handsets but no nothin actually shows up on my mobile.No ring, no call
Posted on Jun 10, 2009
Anonymous
SOURCE: our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Posted on Dec 30, 2009
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
Phones do not ring with incoming calls
Check make sure ringer is turned up,push speaker button then push volume button a volume thing should show up on the screen,keep pushing volume button and it will. Increase the volume.ty.
Feb 15, 2014 | Panasonic KX-TG2632 Twin Cordless Phone
Incoming calls dont ring on my iphone 4
Go to an authorized Apple dealer and let them fix the problem. That sounds like you might have a bug in your phone. (not a literal bug as in insect by the way)
Jan 18, 2014 | Apple iPhone Smartphone
Nokia 2730 - not getting ring tone with some incoming calls. Message left that I have missed a call
If you are facing the problem with some incoming calls it is an indication that you have set different ring tones for different users or incoming calls.
Very simply reset your mobile to a default setting by going to setting, restore factory setting and every thing shall be back to normal.
Oct 24, 2012 | Nokia 2730 Cell Phone
I have a panasonic kx-dt343, i can find the incoming call log but only calls that i've answered not ones i've missed. how do i check the missed calls? how do i set it up so the phone will flash if...
Normally, the ICD group is 601. So, press PROGRAM, pick a button, and dial 54601 STORE. The button becomes a log for all calls ringing into the 601 calling group.
Carl
Sep 22, 2011 | Panasonic KXDT343 Phone
Our phone is not ringing for an external calls but the light is blinking indicating that there is an incoming calls, but calls coming from intercom does ring! meaning our phone is not in silent mode and i...
There are many features which can cause the phone not to ring when incoming calls are on the line. There is a do not disturb key and a mute button on the phone itself. Check to make sure they have not been set. There is an incoming call feature that sometimes needs to be programmed on the phone before it will ring for incoming calls. There is also an automatic answer function that can interfere with ringing too. Instead of listing all of the possibilities, I am including a "cheat sheet" with all of the features & programming for your phone below. Click on the link and scroll through the options to troubleshoot this issue.
If you have any questions please use the comment or reply link near your question on Fixya's website to contact me and I will continue assisting you until this issue is solved.
Sep 14, 2011 | Panasonic KX-T7730 Corded Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Intermittently my iPhone does not ring and incoming calls get forwarded.
Through the iPhone to dustbin and buy a normal phone. It works better than this iphone. This happens to a lot of people.
Jul 14, 2008 | Apple iPhone Smartphone
Wrong phone gets incoming calls.
You can get the alm/sd button light to go off by hitting the alm/sd button twice and then hit the hold button. (I had the same problem
Nov 07, 2007 | Samsung Prostar 816 Phone
Lands Phones Logo
127 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
