Question about Philips 60PW9363 60" Rear Projection Television
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a heard a whining noise, then the screen flashed a couple times and went black, what should i try first?
Posted by jmusgrave918 on
Babiepu
  • 102 Answers
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Posted on Sep 18, 2009
My phillips tv has a green line at the bottom
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Philips 60PW9363 60" Rear Projection...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
I have a Phillips rear projection 60 color lamps off focus
You can't adjust this. Your convergence amplifiers are bad and must be replaced. $250-$350 by repair shop.
Jul 08, 2009 | Televison & Video
My phillips 60 in projection tv has color distortion and the multipoint converge wont let me adjust the cross hairs
Hi..... well if is a LCD Rear projection Tv is a issue with one of the color filters, and you will need to change at least the optical block or the light engine system, I always buy them from www.discount-merchant.com
If TV is DLP it might be a issue with the color wheel, you might be able to hear a buzzing sound.
Jun 27, 2009 | Philips 60PW9363 60" Rear Projection...
Philips 60pw9363 convergence issue
there is a convergence repair kit for ypour model which has both convergence ICs and all 12 Feed resistors at the following link. They also include step by step instructions with pictures of how to do the repair. Heres the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Feb 03, 2009 | Philips 60PW9363 60" Rear Projection...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60 inch HD rear projection? Convergence!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 26, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Convergance adjustment
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Open Questions:
Philips 60PW9363 60" Rear Projection Television Logo
362 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
