Question about Taylor Measuring Tools & Sensors
How to change time on Taylor Precision Products Wireless Digital Indoor/Outdoor Thermometer FCC ID WEC 1502
Posted by LEROY CARLENZOLI on
Richard Marshall
    Habit-Forming:
  • 41 Answers
The Clock display is located at the top of the base unit's LCD screen. The clock has alarm and snooze functions.
A) Clock Setting
1. Press and hold the "SET" button on the back of the base unit for 3 seconds to enter Clock Setting Mode. The year digits flash in place of the clock digits.
2. Press the "+" or "-" button to change the year. Press "SET" to confirm. The month digits flash.
3. Press the "+" or "-" button to change the month. Press "SET" to confirm. The date digits flash.
4. Press the "+" or "-" button to change the date. Press "SET" to confirm. The Day/Month ("D M") or Month/Day
("M D") selection flashes.
5. Press the "+" or "-" button to toggle between Day/Month and Month/Day format. Press "SET" to confirm. A language selection flashes under the "DAY" icon to the left of the clock digits.
6. Press the "+" or "-" button to toggle between language selections*. Press "SET" to confirm the displayed language. Time zone offset digits flash in place of the clock.
7. Press the "+" or "-" button until the correct time zone offset** appears (-12 to +12). Press "SET to confirm the displayed time zone offset. "12 Hr" or "24 Hr" flashes.
8. Press the "+" or "-" button to toggle between 12 and 24 hour clock mode. Press "SET" to confirm.
The hour and minute digits reappear. The hour digits flash.
9. Press the "+" or "-" button to change the hours. Press "SET" to confirm. The minute digits flash.
10. Press the "+" or "-" button to change the minutes. Press "SET" to confirm. The hour and minute digits stop flashing. The clock is set.
Posted on Nov 04, 2019
5 Related Answers
Anonymous
SOURCE: model 6312026 Nexxtech 433MHz wireless
Hello, you have to push few second the mode button and after date, hour etc it will be possible to change F for Celsius. He will flashing and after push one of the two button up or down.
Bye from Quebec Canada
Posted on Nov 20, 2008
Anonymous
  • 3 Answers
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
fixya-surfer
Sys Admin
  • 73 Answers
SOURCE: Acu-Rite indoor outdoor thermometer (model 00754)
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. ALL good now.
Posted on Mar 02, 2011
fixya-surfer
Sys Admin
  • 73 Answers
SOURCE: Acu-Rite indoor outdoor thermometer won't stop periodic beeping
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Anonymous
SOURCE: GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Posted on Mar 21, 2011
Remote not working
Alkaline batteries will not work below freezing in the outside temperature sensor. Buy Lithium batteries for the outside sensor unit alkaline are okay for the inside unit.
Dec 18, 2015 | Taylor Wireless Digital Thermometer with 1...
Springfield precise temp in out thermometer 91756
Return it to the manufacturer for warranty repair/replacement
Jul 23, 2014 | Taylor 91756 Wireless Thermometer With...
Installed new batteries, but need instruction to reset temperature readings
Type "Taylor 1524 manual pdf" in google. That should pull up your manual. Sometimes companies produce the same item, with just subtle changes (product differentiation) i.e. Chevy used the same motor block for the 327,350,400 chevy motors, and just installed different cylinder heads.
Apr 22, 2014 | Taylor 1524 Wireless Indooroutdoor...
Acurite product FCC ID:RNE00782TX What is this electronic gadget?
It is the outdoor sending unit for and indoor/outdoor thermometer. I have had one for years and am looking for another one.
Feb 01, 2013 | Cars & Trucks
Lost my instructions. I replaced the batteries and I can't get it to sinc up.
go to http://www.taylorusa.com/digital-indoor-outdoor-thermometer-1.html and select the link for the manual (Instruction Book under support info, bottom right)
Jan 29, 2011 | Taylor 1522 Indoor Outdoor Thermometer
Outside temperature not showing on ll bean model # 9021u-it
Try removing the batteries from both the outdoor sensor and the indoor unit. I had the same problem and fixed it by doing this.
Sep 28, 2010 | Taylor 1528 Wireless Digital Indoor...
Can't reset Taylor 5367 indoor/outdoor thermom
I changed the batteries on mine and it reset itself. That was easy.
Dec 09, 2009 | Kitchen Appliances - Others
Measuring Tools & Sensors Logo
196 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
