Question about Liebherr Refrigerators
Why Liebherr CS 1651 freezer temperature keep flashing
Posted by Suefen on
Jt de Haan
  • 3 Answers
Snelvrieser aan of temp onder 16 gr
Posted on Aug 19, 2020
5 Related Answers
Anonymous
SOURCE: we have a liebherr 7082
The two flahing lights are normal if the freezer is warm. It will display temperature when it gets cold. If it doesn't get cold there is another problem.
Posted on Aug 09, 2008
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: the freezer keeps defrosting
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 20, 2009
Anonymous
SOURCE: Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
Posted on Nov 03, 2010
Adam Peake
  • 421 Answers
SOURCE: I have a Liebherr 7082
I'm pretty sure that the unit has a fault that will need to be looked at professionally but can you discount the following:
1. Have you put too much fresh food into the freezer without
activating SuperFrost?
2. Does the door close properly?
3. Is the appliance sufficiently well ventilated?
4. Clear ventilation grilles if necessary.
5. Is the ambient temperature too hot?
6. Has the appliance been opened too often or left open too
long?
If you want to have a go yourself you will need to find a service manual. There are quite a few things that could cause the fault you have.
Posted on Nov 13, 2010
tbreeze47
Tom Carson
  • 3083 Answers
SOURCE: I have a Liebherr ref-freezer.
These are quite complicated devices, and many things could be affecting the temperature. Superfrost lowers the freezer temperature to -26 deg, and that could be failing, or you could have a sensor or thermostat problem.
Put a thermometer in the refrigerator, just to check the thermostat reading- also check the freezer side. That will give you a hint if the thermostat is bad.
I would contact Liebherr support, to see what they think, or can do for you. Consult the literature that came with your unit.
Good luck, and hope this helps.
Posted on Nov 27, 2010
Liebherr refrigerator freezer model # cs 1601 79-362-3844 index 101/237 had an inch thick of ice on the bottom. I turned it off using the on/off switch for the freezer and left the refrigerator on.
Is the fan running inside the freezer? To see that you have to remove the back panel of the freezer. Also how much stuff are you putting into the freezer please make sure you are not blocking the vents inside the freezer. Also when you remove that back panel ensure the vent tubes to the fridge area are not blocked.
Jul 06, 2017 | Refrigerators
How do I get my Liebherr CS 1650 refrigerator out of demo mode?
This requires entering the service mode. Typically freezer on/off and suer frost, then change the 'd' setting to 0 by using the up arrow. Press power button to exit.
Nov 29, 2016 | Liebherr Refrigerators
Liebherr problems
Is the temperature, inside, of the freezer, at least zero? Other than that, good luck.
Sep 07, 2014 | Liebherr Refrigerators
I have a Liebherr CUPsl 3221 freestanding fridge/freezer. Does any one know what are the approximate temperatures in the freezer area at different settings? (1-7, manual button in the refrigerator are
Their are no direct connections between the number and the temperatures on refrigerators and freezers. Is is based on surrounding temperature, in the room. That is the reason they used numbers and do not mark teperatures.
May 23, 2014 | Liebherr Refrigerators
We have a liebherr 7082 214 model. We cannot set the temparature for the freezer. after a few seconds the temperature digits disappear and two flashing lights appear
Jul 31, 2008 | Liebherr Refrigerators
Refrigerators Logo
215 people viewed this question
Top Liebherr Refrigerators Experts
Marvin
Marvin
Paul Carew
Lawrence Oravetz
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
