Question about Hioki 3030-10 Analog MultiMeter VOM
Hioki 3030-10 schematic DRAWING and value of R4 and Z1
Posted by Fazal on
  • depasid727
    depasid727 Nov 03, 2019
    my buddy's friend makes $96 hourly on the internet. She has been with out artwork for five months however final month her charge emerge as $12747 really on foot on the internet for some hours. study greater on this net internet site.....
    HERE? www.self.cash61.com
    please don't copy"?" In Url Thanks
What is the value of R4 resistor on the mlt668tl-vm board?
Maybe 0.22 ohm a fuse resistor red red silver gold ? to see on some online pictures but can not see the schematic under the black cool plate.
Hioki 3030-10 hitester resistor. R21 blown. Any kind soul have the value of R21?
If it is working why change it. I assume it is in calibration. package is not value related.
1helpful
2answers
Where can i obtain the schematic(circuit) drawing
If you want any resistance value, ask me. I will send you. Please mail to your burned part number Ex R501, R502
Mail id : [email protected]
3answers
I have a laptop motherboard (da0at3mb8f0) which will not power on. I see a small charred area on the motherboard right on the power input circuit. I want to replace these diodes/resistors but I cant tell...
Even if you would find the parts, it's impossible to repair it - the multilayer board on which they are soldered is shorted and that cannot be fixed.
1helpful
Schematic drawing of Adcom GFA-5300/how to check driver circuits
The driver circuits should be just before the outputs in the circuitry. The easiest way to check this circuit is to remove the outputs and turn on the unit. Measure each of the transistor pads relativce to ground for DC voltage. You should see the following: B+,0.6V (or 1.1V), and 0V on one transistor and negative values on its compliment. If you have questions, measure the pads and post the measurements here. In some cases the output transistor needs to be in place to get the values above, so if yours don't measure that way, just post what you get and we'll continue from there.
Dan
Flm323b power supply
Replace Q2 by 18N50, Q8 and Q9 by STP6NK60 and Z2 and Z4 by !n4739. I have the same problem and fix it.
Hioki 3030-10 Analog MultiMeter VOM Logo
Top Hioki Measuring Tools & Sensors Experts
Tom Chichester
ray gallant
Are you a Hioki Measuring Tool and Sensor Expert? Answer questions, earn points and help others
