Question about Home
I need to know how to use the controller for Wellrest Well rest PFI-DTC-FB1 Digital Electric Blanket 3-Prong Controller (A39)
Posted by Nancy M Sanborn on
5 Related Answers
Anonymous
  • 379 Answers
SOURCE: electric blanket controller light blinking
i had the same problem , i believe it was caused by unplugging the blanket plug while it was in the on position , i unplugged it from the wall and it like reset itself , worked for me.
Posted on Dec 20, 2008
Anonymous
SOURCE: electric blanket does not warm
Call the manufacturer. They will often do repair for free.
Posted on Dec 31, 2008
Anonymous
SOURCE: ELECTRIC BLANKET CONTROLLER FLASHES RED BUT DOES
You can find the Customer Service phone numbers for ALL the major electric blanket manufacturers at www.electricblanketinstitute.com/contact-information.html.
Posted on Mar 15, 2010
woodzowl307
  • 667 Answers
SOURCE: my sunbeam electric blanket - the heat controller ...
do away with the blanket, as it is an electrical issue, hazard!
Posted on May 22, 2010
tunde007
Tunde Autos
  • 2382 Answers
SOURCE: need a schematic for Sunbeam
Hi, the schematics for the electric blanket are not readily available online maybe due to the company's policy just like some others that i know. You may try your luck by contacting Sunbeam on (800) 667-8623 to make a request for the schematics.
Posted on Oct 05, 2010
I have an perfectfit electric blanket. Yesterday the control would light up and then after five seconds turn off. I checked the connections. Can this be fixed? I love this blanket.
My best guess is maybe... If its the model where the controller can be unplugged from the blanket then i would try and get a new controller for it, if its the cheaper model they sell that the controller is permanently on a cord from the blanket then most likely not. The other problem is generally they shut off when there is an issue, it could be a broken connection or broken heating element in the blanket itself and its shutting back off due to the fault. So best suggestion i can make, see if you can find a replacement controller or contact their customer support about getting a replacement, if the controller costs almost as much as a new blanket then just get a new blanket. I know how nice an electric blanket is!!
Jan 11, 2018 | Home
I need a manual for a Serta electric warming blanket programmable digital controller
Hello, Kathy -
I don't own such an electric blanket, so I can't provide you information on how to use the programmable digital controller.
If you have not yet called Serta Customer Service and asked your question, I believe that will be the best source:
Call 1-888-557-3782
Monday - Friday, 9am - 5pm (Eastern Time)
Needless to say, you will need to wait until Tues. Dec. 26 to call.
Dec 23, 2017 | Home
Our dual control Sunbeam electric blanket is 3 months old and is not heating up, however the powere is on both controls
Should have warranty, plug and unplug the connection to blanket several times. if no help call their customer service. You may be able to return it to the store you bought it from and get a replacement. Hopefully, you still have receipt.
Feb 28, 2015 | Sunbeam Electric Blanket Dual-Controller -...
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
Dec 13, 2013 | Simmons Beautyrest Microfleece Electric...
Electric blanket won't heat
Take the help of your mattress pad company or look into instruction manual. Do not operate it unless you are familiar with it. You should call the customer care to know how to operate.
Jack from Coriumdirect Mattress pads
Apr 07, 2013 | Biddeford Blankets Heated Mattress Pad...
Double control electric blanket. only one controller working.
I would say that you probably have a bad controller but it's possible that you have one side of your blanket thats bad. I would take the control that you know works and put in on the side that doesn't.Turn it on and if the blanket works that tells you the control is bad.
If you have a multi meter you can unplug power cord from the side that you know works and set your meter to ohms and check the resistance, Next due the same thing on the side that you are having problems with and if the reading is the same or close that also would indicate that blanket is ok and you need one new control.
I hope this helps you .Thank you and have a good new year.
Jan 04, 2011 | Heating & Cooling
I need to find a replacement control unit for the following electric blanket: Sunbeam 33600 RN 17280 PN 107882-003 Style 84 SK If anyone could point me in the right direction, I'd really appreciate it.
I have the same numbers on my blanket, mine has a PAC-215 controller, I found a couple of them on ebay. Don't know it all blankets have the controller so check the numbers on the back of your controller.
Jan 12, 2010 | Sunbeam Heating & Cooling
Electric blanket does not warm
Dec 03, 2008 | Heating & Cooling
Home Logo
166 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
