Question about Furniture
Stressless 2 Seat Sofa, broken mechanism
The left hand side anchoring bolt has come undone
Posted by Rosemary Turnbull on
5 Related Answers
dragonsthatk
Albert Getty
  • 547 Answers
SOURCE: glass panel for passenger window 2002 Audi TT convertible?
yes you need to order the right glass you cannot cut a hole in temperd glass sorry and good luck
Posted on Feb 11, 2009
Anonymous
  • 3 Answers
SOURCE: dropped jewelry (ring) down between driver seat and consol.
yes it should she be 4 bolts, two in front and two in back. If its electric just be careful to not rip any wires
Posted on Jun 10, 2009
toyotech6
  • 318 Answers
SOURCE: The left side bolt on the driver's seat on my 2001
The recieving nut is welded to the car by the toyota factory. Just insert said bolt and screw.....
Posted on Jul 10, 2009
Richard Scordino
  • 6982 Answers
SOURCE: a support under the driver's seat in my 2004 Jeep
Since you are unsure what is broken I can't tell you how to fix it. BUT, You can go to just about any scrapyard and look at the seats they have, first to see what yours used to look like before it broke and then, if it is anything that will need welding etc, possibly to buy the seat you looked at (not terribly expensive compared to some repairs)
Posted on Nov 11, 2009
SOURCE: I need to install a baby seat in my 1996 lancer
Check your owners manual!
Posted on Mar 31, 2010
Kohler cimarron broken seat, replacement parts don't work 2x's
No do not use metal bolt and nut as this can crack the toilet. Just go to Lowes or Home Depot and buy 2 plastic bolts , 2 plastic wing nuts, and 2 plastic washers. Install with seat through toilet holes and tighten by hand until tight. I then use pliers to tight just a turn tighter and the seat should be center as you tightened one side, then the other, and back again until tight.
Mar 17, 2013 | Kohler Cimarron Comfort Height 2-Piece 1.6...
Hi, I would like to know if the front seat belt retractors for Honda CRV 2003 are the same? If yes, is it difficult to replace the seat belt assembly? I'm planning to buy a used front passenger side...
I don't know if this is something you want to get into? You decide. Front Seat Belt Replacement SRS components are located in this area. Review the SRS component locations and the precautions and procedures before performing repairs or service.
NOTE: Check the front seat belts for damage, and replace them if necessary.
Front Seat Belt
  1. Make sure you have the anti-theft code for the radio, and then write down the frequencies for the preset buttons.
  2. Disconnect the negative cable from the battery, and wait at least 3 minutes before beginning work.
  3. Slide the front seat forward fully.
  1. Pull the lower anchor cover (A) back, and remove the lower anchor bolt (B).
  2. Remove the B-pillar lower trim panel.
  1. Remove the upper anchor cover (A), and remove the upper anchor bolt (B).
  1. Disconnect the seat belt tensioner connector (A), and detach the harness clip (B) from the retractor (C). Remove the upper retractor mounting bolt (D), and the lower retractor bolt (E), then remove the front seat belt (F) and retractor.
  2. If necessary, remove the front seat belt protector (G).
  3. Remove the B-pillar upper trim.
  1. Remove the shoulder anchor adjuster (A).
  1. Install the seat belt in the reverse order of removal, and note these items:
    • Assemble the washers, collar, and bushing on the upper and lower anchor bolts as shown.
    • Check that the retractor locking mechanism functions.
    • Apply liquid thread lock to the anchor bolts before reinstallation.
    • If the seat belt tensioner has been activated, replace the front seat belt protector with a new one.
    • Before installing the anchor bolts, make sure there are no twists or kinks in the seat belt.
    • Make sure the seat belt tensioner connector is plugged in properly.
    • Reconnect the negative cable to the battery.
    • Enter the anti-theft code for the radio, and then enter the customer's radio station presets.
    • Reset the clock.
    • Do the PCM idle learn procedure and the power window control unit reset procedure.
Upper anchor bolt installation
Lower anchor bolt installation
Seat Belt Buckle
  3. Remove the front seat.
  4. If equipped, remove the center table.
  5. Remove the under seat storage box.
  6. Remove the center cover, driver's, passenger's.
  1. Driver's: If equipped with seat heater, remove the harness band (A), and disconnect the seat subharness connector (B). If equipped without seat heater, detach the seat belt switch connector clip (C). Detach the seat belt buckle tensioner clip (D), and harness clip (E).
Dec 11, 2017 | 2003 Honda CR-V
How do iremove front seat from a 1997 honda accord
1. Make sure you have the anti-theft codes for the radio and the navigation system, then write
2. Tilt the steering wheel all the way up and telescope it all the way in.
3. '04-07 models passenger's seat: Carefully insert the tip of a small screwdriver (A) through
the hole in the back of the front seat belt lower anchor cover (B) and into the hole in the
front seat belt lower anchor (C). Unlock the lower anchor by pushing in on the screwdriver.
Remove the screwdriver, and then detach the front seat belt anchor plate (D) and anchor
cover from the lower anchor.4. Slide the seat all the way forward, then remove the seat track end covers from the back of both seat tracks.5. Slide the seat about half way to the rear so you can access the seat mounting bolts. If equipped with the driver's 8-way power seat, fully raise the seat.
6. If equipped with a side airbag, disconnect the negative cable from the battery, and wait at
least 3 minutes before removing the seat. 7. Remove the bolts securing the front seat. 8. Lift up the front seat, then detach the harness clip and disconnect the connector.
If equipped, the seat heater connector on the 2-way power seat and passenger's
manual seat. '04-07 models, disconnect the seat position sensor subharness connector on the
driver's manual height adjustable seat and the driver's 8-way power seat.
9. With the help of an assistant, carefully remove the front seat through the front door opening. 10. Install the seat in the reverse order of removal, and note these items:
Apply medium strength type liquid thread lock to the front seat mounting bolts
Make sure each connector is plugged in properly.
Tighten the seat mounting bolts to the specified torque in the sequence shown.
Slide the seat all the way back and tighten then slide it forward and
tighten Before attaching the lower anchor bolts, make sure there are no twists or kinks in
the seat belts. 04-07 models passenger's seat: The triangle marks on the anchor plate and
the lower anchor must face the same side. Insert the anchor plate into the lower
anchor, and make sure that it is locked securely. If equipped with a side airbag, reconnect the negative cable to the battery. Enter the anti-theft codes for the radio and navigation system, then enter the radio station presets. Reset the clock. Your all done. Drink a cold beverage and enjoy the rest of your weekend! hope this helps. Dave
Jun 16, 2011 | 1997 Honda Accord
How to remove the rear seat of a Honda Ridgeline 2010.
1. Pull the plastic panels under the seat bottom straight forward to remove them.
2. Remove the six bolts (14mm) holding the seat and center seatbelt in place.
3. Pop the two small plastic covers at the top and behind the seat using a trim removal tool or screwdriver tip covered in masking tape.
4. Lift the seat straight upward.
5. Remove.
The Service Manual states a 35 ft lb torque and must be re-installed in a certain sequence for the 6 seat anchor bolts (not the seat belt bolts). When putting the rear seat back in install the bolts in this order. (1) center left (2) center right (3) left lower (4) right lower (5) left upper (6) right upper.
Nov 09, 2010 | 2008 Honda Ridgeline
How do I remove the front seats to lubricate the power seat machinery?
LIFT CARPET AND UNBOLT SEAT ANCHOR BOLTS WHICHARE LOCATED ON THE SEAT ANCHOR BRACKETS UNDER THE SEATS FOUR CORNERS DISCONNECT THE WIRING AND YOU WILL SEE THE MECHANICAL PARTS UNDER THE SEAT AT BOTH SIDES USE A SMALL AMOUNT OF GOOD QUALITY GREASE MAKE SURE YOU LUBRICATE ANY METAL TO METAL PARTS THEN REVERSE THE DISSASEMBLEY PROCESS HOPE THIS HELPS
Nov 08, 2010 | 1996 Toyota Land Cruiser
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
Get seat of Kohler K-3386
Roberta3fan could be giving bad advice based on experience with other toilets. This does not seem to be an option for this toilet design. I am in a similar situation and it appears that the nut (and it is a metal bolt) is not what you would expect. Here is a picture of the anchor kit for this toilet seat: http://www.plumbingsupply.com/images/kohler-anchorkit-84999.jpg I am going to assume that the sleave that should be engaging the bolt is cross threaded and try to grab it with a pair of vice grips. I'll let you know if it works.
Jan 09, 2010 | Kohler K-3386-0 Rialto one-piece...
My 2002 bmw 525i has broken front seats. When I
This is a common BMW problem before giving to a mechanic try looking at the mechanism to see if any bolts are loose or missing,you might find the bracket is broken or torn and needs to be welded or replaced,the job is relatively easy but be carefull because of the SRS system if not sure give it to an expert.
Jul 10, 2009 | BMW 525 Cars & Trucks
I need to replace a rear seat belt in a 1997 Ford Tarsus. Does any know the best way to access the assembly? In addition, are there any diagrams available that show the connection points?
please don't forget to rate, thx.
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Safety Belt Bolt Bit T77L-2100A
NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
  1. Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear Sedan
Removal
  1. Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
  1. Remove rear seat cushion from vehicle.
  1. Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear 60/40 Split Bench—Sedan
Removal
  1. NOTE: Safety belt bolts do not secure seat back to vehicle.
    Remove rear seat cushion as described.
  1. Fold down back seat and remove two bolts in the center of each seat back striker plates.
  1. Remove two bolts from outboard rear seat back frame retaining brackets.
  1. Lift seat back up and pull forward to remove from vehicle.
  1. Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan Removal
  1. Remove rear seat. Refer to Section 01-10 .
  1. Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
  1. Pull lower quarter trim panel away from body.
  1. Remove safety belt retaining bolt.
  1. Feed safety belt through lower quarter trim panel.
  1. Remove safety belt anchor plate-to-sill bolt from quarter panel.
  1. Remove retractor anchor nut and retractor from rear quarter panel.
  1. Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
  1. Slide anchor plate end of safety belt through the openings in the quarter trim panel.
  1. Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
    Item Part Number Description 1 386277-S190 Bolt (Part of 611B68) 2 31012 Upper Rear Quarter Trim Panel 3 611B60 Retractor and Tongue 4 N800937-S190 Nut 5 389370-S190 Bolt 6 — Rear Quarter Panel (Part of Body) 7 52018 Lower Rear Quarter Trim Panel 8 — Mounting Stud (Part of Body)
  1. Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
  1. To install, reverse Removal procedure.
  1. Make sure the safety belt webbing is not twisted. If it is, remove the twist.
  1. Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
  1. Check the restraint system for proper operation.
Jun 30, 2009 | 1997 Ford Taurus
Furniture Logo
107 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
