Grill works. fan works
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
The reason for my free advice is GOD is good!
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
SOURCE: smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
SOURCE: SMEG SA410X-S heat not coming on for fan forced
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
