Question about Samsung Office Equipment & Supplies
My Samsung SAM ER 650 will not print X or Z reports.
I was using it with another register and reporting via IRC worked fine, but now that it is stand-alone, it will not print the reports. It will display them, but when I choose "Print", it doesn't and the screen goes back to the report screen. In the SM mode, I have set the IRC option to be from reg. 1 to reg. 1, but still no luck. Any ideas? Thanks.
Posted by TomV on
5 Related Answers
Anonymous
SOURCE: Disabling Auto-Print of Communication Result Report
It's in the "user parameters" in the "fax features" menu. No disrespect, but it's a needlessly complicated setting (all of the parameter settings are if you aren't familiar with Ricoh).
You can download the manual here if you don't have one (It's in the Printer /Scanner reference). Look in the index under "Communication result report".......good luck:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp16/mp16en.htm
Posted on Mar 12, 2009
Anonymous
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue canon mx700 fax report problems
after emailing canon support, the answer is this: 1) the fax paper size must be "letter" - 8.5-11". 2) reset all settings through settings menu. the fax will then print reports (and also every report that was not printed before).
Posted on Jun 14, 2009
mikeywaf
Michael Wafkowski
  • 346 Answers
SOURCE: I have a Samsung scx-4521X
Hi - The manual (as you probably know) just says "recently sent" and doesn't specify for how long and there does not appear to be any setting to modify the report
Since it doesn't actually print the whole fax but just basic info like number faxed to, date-time, pages, fax title, etc. why don't you just print the report and see?
Thanks for inquiring at Fix Ya.
Mikeywaf
Posted on Mar 15, 2011
Electroboy
Electroboy
  • 1866 Answers
SOURCE: Casio TE 4500f till register,
You have turned the key before you finished in the previous mode. Turn the key until the mode error stops (not counting the off position). That is the mode you need to finish. Try pressing SUBTOTAL in this mode and then turn the key
Posted on Sep 12, 2011
frank_yd
FDFDFD
SOURCE: Zebra Printer / SQL Reporting Services print problem.
Same issue, please help!
Posted on Sep 10, 2014
I can't get the key to turn into the SM mode to clear the grand total history.. I would like to do this before I use the machine
Cash Register Help: SAM4s ER-650 Cash Register
cashregisterhelp.blogspot.com/2008/05/sam4s-er-650-cash-register.html
May 1, 2008 - I really like the SAM4s ER-650 Cash Register and ER-650R Cash Register. ... By the way the SAM4s ER-650 and ER-650R is the same as the Samsung ER-650 and ... I can't seem to figure out how to program it to track ticket/check #'s. .....also, neither the Reg Key or Mode Key will turn to SM mode. help?
Samsung Cash Registers ' ER650 Bar Code Scanner ...
www.maxperience.com > ... > Cash Registers
If not, you will need to go to the SM mode and configure either RS-232 port 1 or port 2... Press enter (cash key) through the rest of the options. ... I could not get the curserinto the plu numeric field once i entered the plu. .... There are manuals for the SAM4s ER-650 at http://www.cashregisterguys.com and if you are looking for ...
Samsung Cash Registers ' Samsung ER 650 Deleting PLUs ...
Dec 01, 2015 | Samsung SAM4s ER-650 Cash Register
How to delete a plu
to delete a plu it must have no totals on either the plu current or today report. Run a plu z report both current and today and then delete the plu
Mar 07, 2015 | Samsung SAM4s ER-650 Cash Register
How do I program my second register using my first register
first program the irc options (#7) in the service mode making one register 1 and one register 2 . also make the max # of reg 2. then program memory allocations to be the same in program. finally connect the two with a pin to pin cable and go to download programs to send
Mar 04, 2015 | Samsung SAM4s ER-650 Cash Register
Unable to print X or Z Report
Could be you've a couple of busted RAM chips there. Have you ran a diagnostic?
May 11, 2014 | Samsung Sam4s ER-5240M Cash Register
ER 380 Z AND X reports not working
turn key to "x" mode
Press "1" and "subtotal"
turn key to "z" mode
Let us know how you go
Thank You
Team
ACP ONLINE
Jul 09, 2013 | Sam4s Samsung ER-380 Cash Register
I have 4 sam er650s usually linked together
check your cables, then re-identify your tills(till numbers)
Jan 15, 2013 | Samsung SAM4s ER-650 Cash Register
Cash register Sharp ER-A420 Z report
Ther is a possibility that your machine was operating on training mode. In this mode , no memory is kept
Oct 11, 2012 | Sharp ER-A420 Cash Register
37 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
