Question about Cooking
Powerroll electric cigarette machine will power on but when i push the lever it does nothing
Posted by Sandy Beecham on
Sherri Manuputty
I have a manual cigarette machine that does one cig at a time. If my tobacco is too damp, it compresses and won't work at all.
If that's the problem with yours, just leave some tobacco out on a tray to dry a bit, or (what I do, if I am in a hurry, ha) is let it fall from my fingers slowly in front of a heater onto the rolling tray. A couple of times and it's good and works fine.
The tobacco I buy is always dry, so I put half a potato or some bread in there to get it moist again and usually I overdo it.
Posted on Jun 28, 2020
Nick Hooo
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Check the loading of tobacco. Visually, there are too many or few. Also check paper loading.
Posted on Feb 02, 2020
Need user guide for a powermatic 2 cigarette injector machine
Contact vendors on Amazon.com or other sites:
Example:
https://www.fandfwholesale.com/powermatic-ii-electric-cigarette-injector-machine.html
Quoting from link above:
"Powermatic II Cigarette Injector is an electric, spoon fed injector and the first product of its kind we've carried in quite a while. We have been very impressed with the function and ease this product offers. The spoon fed style of this injector eliminates many of the issues that other auger driven injectors have. This machine will make both king size and 100 mm tubes and features electronic jam protection to ensure that that the machine does not break from overfilling the chamber. The compact and lightweight design of this machine allows for easy use and storage. The large tobacco fed hopper and removable tobacco tray, will be sure to have you rolling cigarettes in three easy steps. 1. Plug in and turn on the power. 2. Lift the lever and fill the tobacco evenly. 3. Press the lever fully down to start filling your tubes. The product includes accessories to clean your machine and comes with a 1 year manufacturers warranty. Please fill out warranty card and mail in upon receiving machine. Machines cannot be sent back to Smokers Outlet Online, Inc. for refund or credit. -------------------------------------------------------------------------------- For Warranty service, all machines must be sent to: Powermatic Service Center 17005 Evergreen Place Suite B City of Industry, CA 91745 1-626-964-5678 zico.com@verizon.net"
Aug 17, 2018 | Cooking
Powerroll top o matic electric cigarette rolling machine will not turn on when plugged in
CHECK MACHINE SOME TIMES THE WORKING PARTS NEED
SOME CLEANING USE SOME SEWING MACHINE OIL JUST A DAP AND CHECK GEARS MAYBE YOU MAY HAVE SOME LINT
OR A HAIR.
D,R,CLAUDIO
Dec 29, 2017 | Cooking
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Can I buy a power cord for a Powematic 2 cigarette machine ?
If you have a laptop cord thats 2 piece you can use the first part of the cord to run your machine just tried it and it works.
Dec 15, 2015 | Powermatic 2 Electric Cigarette Injector...
I have the exact same problem. This is a Fortress Scientific 2001LX C series. Not sure what exactly the free wheel lever is, but I'll assume that it's the lever that touches the tire? You can't budge this...
MaryJain The scooters freewheel lever should be at the right rear of the scooter under the shroud and no it shouldn'd be touching the tire. To put it freewheel you should push the lever down. Now if the lever is rubbing the tire you can try to get someone to push it sideways toward the left tire to get it away from the right tire. It should move easily into and out of gear. Be careful not to break it or the small micro switch on the brake. Hope this helps you
Oct 27, 2010 | Electric Mobility Mobility Electric Power...
#MDB7851 AWBo maytag dishwasher It just wont start
Check the breaker that serves the dishwasher--push off, than on. If still nothing, check for power at the electrical junction box under the front. Check the door switch--push up on the latch lever that sticks out of the case slowly and listen for a light 'click'. Hold this lever up and try to run it. It may be just adjustment or actual switch replacement. If this has no effect, then you may need to replace the control board.
Aug 21, 2009 | Dishwashers
Singer 7426 will not start when peddle pushed - only beeps
No, dont go and buy another machine. This is a great value for money machine.
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. Pull it down and push it up to the top again. This should sove your problem right away.The beeping sound is a warning message. If the problem persist, do the following procedure:
Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Nov 14, 2008 | Singer 7426 Mechanical Sewing Machine
Cooking Logo
255 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Cooking Expert? Answer questions, earn points and help others
