Question about Hardware & Accessories
My aquaswitch timer "time of day" won't advance. replaced orange timer with red one. it lasted 2 weeks. replaced it again. this time it lasted 8 weeks. I hate to buy another timer. Any suggestions??
Posted by Jim Hughes on
5 Related Answers
Anonymous
SOURCE: Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Posted on Mar 01, 2007
Anonymous
  • 72 Answers
SOURCE: Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Posted on Nov 11, 2007
AoverK
SOURCE: ERROR CODE 34 on Mitsubishi TV
I just had the same issue with my TV (dont know code), but the issue was with the power supply.
Posted on May 04, 2008
Anonymous
  • 51 Answers
SOURCE: 3 blinking lights - Samsung DLP
Remove your new bulb and examine the connector carefully. The inexpensive replacement bulbs tend to arc and ruin your $700 ballast; sad to say. If everything looks good, make sure the interlock switch on the bulb cover opening is engaging. It won't fire up if it thinks that door is open.
Posted on Dec 27, 2008
Anonymous
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
Posted on Dec 24, 2010
Repeated starter housing breakage in 2001 windstar
you need to have a spacer put it ther to take up the slack in it ther was won in ther probably at won time or another replace it go to the dealer to make sure you HAve the Right One For Sure then go some Were Else to put it in and ask them Please can you Help Me Please Rember Be Nice And Be Thank full afterwards Ok
Jan 03, 2014 | 2001 Ford Windstar
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
Ferroli optimax he plus 31c boiler timer instructions
Why does the display appear and i can set timer but then display goes blank and i carnt getthe lcd screen to display anything at all??
Dec 19, 2011 | Heating & Cooling
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 27, 2011 | Intermatic R8806P101C -...
Had to change battery. Since I did this the day will scroll several times and will not let me set the day, nor the time, nor the mode. Is my unit toast ?? As it was working till I changed the battery.
Most digital timers suggest resetting as last-step effort to restore functionality.
This particular timer is reset by removing battery.
Try removing battery again. Otherwise it seems the timer has gone bad.
HB88RC is discontinued product.
Replacement is heavy-duty Intermatic HB800RCL 2-outlet or HB800RCH 1-outlet timer.
http://www.smarthome.com/25078/Intermatic-HB800RCL-Heavy-Duty-Digital-Appliance-Timer/p.aspx
http://www.smarthome.com/48715/Intermatic-HB800RCH-Outdoor-Digital-Timer/p.aspx
Less expensive and less reliable timer Woods 59403 with 1-outlet has quite a few 'timer won't work' questions on fixya.
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Jun 19, 2011 | Intermatic HB88RC - 7-Day Programmable...
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Freezer frosts up and stops cooling after approximately 2 weeks
With your new timer in hand look and find a slotted screw driver head that you can turn. That is to manually advance the timer. Now put the new one in and advance it to engage the compressor and fan. Might be in the middle of defrost mode. Your unit goes through 3 defrost modes in a 24 hour period. And each mode last for 20 minutes. Once you do this I could help further if that was the case. Okay ken
May 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Need instructions for a Timex Timer Moder #TE111 (TX12694TA)
To set the timehold down the TIM button until Day flashes, Use +/- to adjust then hold down time until hour flashes..Repeat until set.
To program,
1. hold down prog until the cursor starts to flash at 12:00
2. Press PROG to advance to the day or day group you want to program.
3. press + to advance the cursor to the desired ON time
4. press mode until display reads "on"
5. use the + to move the cursor to the desired ON duration? Clock shows this also.
6. press mode until "off" is displayed. then advance the cursor thru the period the outlet should be off. (stupid to have to do this!)
7. press MODE to select as the ON or OFF period(!)
8. press TIME to exit programming.
9. Press PROG again to program another set of days.
Stupid system.
Good luck.
Dave
Nov 23, 2008 | Hardware & Accessories
Defrost solution didn't last....
If it does not defrost after turning the timer then the problem is further into the defrost circuit. If it does defrost when you turn the timer and that is the only time it does defrost replace the timer.
Aug 05, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Hardware & Accessories Logo
122 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
