Heater kicks off after a few mins.pro temp 70,000btu
Posted by Mark Johnson on
J Rosado
  • Heating & Co... Master
  • 1,201 Answers
If it's forced air, make sure the temperature sensors are working. One sensor starts the fan motor, another sensor is high limit for temperature cut off.
Posted on Oct 06, 2020
JBR Technical services
    Passionate:
    Visited the website for 10 consecutive days.
  • 94 Answers
Sounds like the high limit switch is bad.
Posted on Oct 05, 2020
5 Related Answers
Anonymous
SOURCE: reedy heater 110 pro
Sounds like your pressure screw on the back could need adjusting or look at your manual under troubleshooting it will give you the correct answer to your problem.
Jeffdtect
Posted on Feb 18, 2008
Anonymous
  • 92 Answers
SOURCE: pro 155 kerosi ne heater
Check your fuel and air lines for leaks, typically it's the CAD flame sensor but if you have already replaced it try checking the high heat limit switch. It looks like a thick watch battery just behind the combustion chamber, take it off and hold a lighter under it. If it's working properly you should hear a faint click when it shuts off, no click then it's bad.
Posted on Feb 03, 2009
Anonymous
  • 92 Answers
SOURCE: sealy space heater,shuts down
the motor is going bad. I would like to help you more but really the only thing you can do is replace it and your problem will be solved.
Posted on Feb 08, 2009
Joe Hogan
  • 10865 Answers
SOURCE: I have a Reddy Heater 70,000BTU without a
hello. Your reddy heater is dirty and needs a good cleaning. Also, here are a few other possible reasons why it won't operate properly. Pressure not adjusted to 5.1 psi, dirty outlet filter, clogged inlet filter, bad or dirty photo cell, defective reset switch, pump going bad, dirty injector nozzle, dirty fuel filter, contaminated fuel. Check yours out and do what you can to address each area of concern. Regards, Joe
Posted on Jan 21, 2010
Absi Amri
  • 39 Answers
SOURCE: my 2003 toyota sequoia temp
if both fans are working normally... you need to check radiators (both engine and A/C: start with the big one.. could be dirty blocking flow of coolant!)
good luck
Posted on Nov 18, 2010
I have a dayton Furnace. The furnace will kick on run for few mins then kick off. It trys several times. When this happens my husband replaces the linit switch which usually cures the problem. But my...
If it is the limit switch that appears to solve proble sounds like you are overheating exchanger (not moving enough air over heat exchanger. with goo thermometer check with heat on discharge air temp and retuen air temp difference in temp should be in range of number stamped on unit name plate for acceptable diff . If diiff you read is over nameplate rating must correct air flow and also check for restricted flue exhaust too.
Nov 19, 2012 | Dayton Gas Furnace Heater
I have a 2000 Dodge Ram 1500 that will blow cold and hot air for only a few minutes. After that is only ambient air temps. It is a 5.7 ltr, automatic with only one set of climate controls. The heater core...
you say it will blow cold and hot air for only a few minutes. You don't say but I assume you mean will blow cold a few min. when turned on AC max , blow hot only a few min. when turned to heater hot. Assuming thats the situation and you say AC charged and shows good on the low side -you should charge the AC to a full charge on the low side will cause problems with the AC air compressor kicking on and off. I suggest while the engine is running and turned to AC cold max watch the AC air compressor clutch to see if it does indeed kick on and off if so charge completely. As far as the heater make certain you coolant is all the way to the top and the best way to do this is when engine is completely cold remove radiator cap and fill completely and completely close cap then fill overflow container just to the cold level. That should fix your problem.
Sep 06, 2011 | 2001 Dodge Ram 1500 Truck 2WD
1998 rover 214. after few mins of switching car on, the water bottle will start to bubble like mad,and its like a creamy gunge,if i switch my heaters on, the heaters stay cold and the bubbling in water...
This sounds like you have an air bubble in your system, I would pressure test for leaks. The creamy grunge sounds like oil in the coolant...if that is the case, exploritory surgery is the next step.
Jul 16, 2011 | Heating & Cooling
My kerisene heater turns on for a few minutes than the safty braker kicks out
check the fan their are very little parts that would cause that the main one is the fan
Sep 12, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
My 2003 toyota sequoia temp goes up when outside temp is very hot.Mya.c will shut off then kick back on and repeat. After about 4 min the temp gauge goes up and heater kicks on .What could be causing this?
good luck
Aug 27, 2010 | 2003 Toyota Sequoia
I have a Reddy Heater 70,000BTU without a thermostat. It will flare off and within a few seconds the fire goes out and then the it trips out. After a few tries it won't even flare off. What might be wrong?
Jan 21, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Have a 70,000btu ready heater. changed ignitor & pump set press.
If it shuts off it may be a problem with the thermocouple which needs to reach a certain temp so that the heater knows it is lit to continue sending fuel and air. If this is not operating propoerly it can cause the problem you are describing. You can check if this is the case by testing for continuity across the disconnected thermocouple leads while holding a lighter on the thermocouple. At room temp you should not have continuity, when it heats up the circuit should close. If this is not happening it may be bad. You can further test (CAREFULLY) by jumping the thermocouple leads where they come back to the control board. If it continues to run that is your problem. Also make sure the thermocouple is aligned properly to get heated by the initial heat or it will never warm up enough to close the circuit and allow the heater to continue to run...
Hope that helps...
Feb 09, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Sealy space heater,shuts down
Feb 08, 2009 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
