Heater kicks off after a few mins.i have a pro temp 70,000 btu pt70t-kfa.
Posted by Mark Johnson on
Kenneth Simmons
  • 1,139 Answers
5 Related Answers
Anonymous
SOURCE: reedy heater 110 pro
Sounds like your pressure screw on the back could need adjusting or look at your manual under troubleshooting it will give you the correct answer to your problem.
Jeffdtect
Posted on Feb 18, 2008
Anonymous
  • 3 Answers
SOURCE: Dyna Glo Pro RMC-KFA70TDGP 70,000 BTU Torpedo heater not igniting
The main circuit board supplies ac power to the ignitor ( black transformer looking device) and the transformer increases the voltage that is supplied to the sparking device. Make sure the wires are connected to the sparking device and the ends of this device are approximately 3mm apart and that it is in the general position near the end of the nozzle. If you do not hear a "clicking" sound it could be the main board, wires or sparking device.
Posted on Dec 17, 2008
tbugger
Jerry Magee
  • 232 Answers
SOURCE: 70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Posted on Feb 11, 2009
Anonymous
  • 9 Answers
SOURCE: I have a Hayward propane pool heater (60,000) BTU.
When the heater lights is there a hard whooshing sound? If so, then you might be experiencing a "concussion" light.....this means that the gas puddles before igniting and "explodes" when it hits the pilot flame. This concusssion will extinguish the pilot and the pilot generator will start to lose voltage until it drops below the minimum required for gas valve operation.
Posted on Jun 28, 2009
Anonymous
  • 193 Answers
SOURCE: 110,000 btu all-pro heater 2years old ,runs 2 mins
take off rear plastic filter end cover. check very close for hair line cracks and make sure that plastic rib that seats around cork portion of gasket is not warped
Posted on Sep 25, 2009
Protemp heater is not running right and blowing black smoke before it kicks on
Sounds like you need a new nozzle and filter. Clean the pump strainer too.
Dec 09, 2013 | Milwaukee Tool Master Heater 70,000 BTU...
Hello, I have a 70,000 btu readdy heater that don't want to ignite. When I pull the top cover off the heater works fine, but the minute I put the cover back on it does not want to ignite. I'm stumped.
Does your heater have an oxygen sensor on it? If so try gently cleanig dust,lint or other debris from it . If that does't help I would replace it. I hope thishelps you. Thanks
Nov 25, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
My heater starts runs for a few min,then shuts down if i remove the top where the handle is it will run indefinatley put on the cover with no screws and it shuts down
check for cracks in plastic cap around air vent adjusters, mine did the same thing, found cracks and used glue for now, sucking too much air and sending too much fuel, runs great and doesn't smell bad anymore,
Oct 31, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater-50,000 won't fire, fan comes on for few seconds than shuts off
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Sep 17, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
No fuel but ignitor comes on but no motor or fuel?
You must troubleshoot to see if the motor is getting 110 volts.
The problem could be the board *or* it could be the motor.
Dec 28, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
