Question about Whirlpool Microwave Ovens
I have a built in Whirlpool GT4175SPS-4 and want to replace it without having to change the trim kit. Is there a replacement with the same dimensions? Whirlpool?
Posted by Bob Brandt on
Tom Chichester
    Top Expert:
  • Whirlpool Master
  • 55,375 Answers
Refer this directly to Whirlpool.
Posted on Mar 24, 2020
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: TRIM KIT INSTALL
Phone these guys at maytag - sorry info is not available online 1-800-688-9900. Hope this helps :)
Posted on Mar 10, 2007
Anonymous
SOURCE: Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Posted on Nov 22, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: I have the same problem
GE Customer Service is here and they should be able to tell you what the "drop-in replacement" is for your model.
Of course, most microwave problems are pretty simple to repair.
If you're interested in our advice there, please reply back with your detailed symptoms.
Otherwise...
Posted on Jun 08, 2009
Philip
  • 949 Answers
SOURCE: whirlpool gold microwave gt4175sps - problem: will
It sounds like there may be a diode or relay on the control that has failed. This could cause both symptoms you are explaining here. In either case the control board/keymembrane would need replaced. The cost of these would be about $173.00 for parts. Unfortunatly this repair would most likely cost more than the value of the product. Sorry for the bad news.
Posted on Apr 18, 2010
gebroken
SOURCE: What are the dimensions for
30" wide x 16" tall x 14" deep. Tried to find a replacement for mine of that size with no luck. Turned out a $30 capacitor needed replacing ($90) service charge.
Posted on Oct 24, 2010
I bought a KitchenAid 24" microwave oven and trim kit.to replace an old KitchenAid 24" oven. The old oven set on the built-in shelf with a stainless steel trim panel around the oven to trim the cut-out. ...
As long as there is ventilation at the back and somewhere for the air to come out go ahead and use you imagination to make the trim kit look good to the eye. Making those tough decisions is what installers do.
Oct 17, 2013 | KitchenAid Microwave Ovens
My whirlpool gold gt4175sps lights up and the control panel works but the turntable does not spin and it does not cook. No fan or cooking noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 16, 2011 | Whirlpool GT4175SPS Stainless Steel 1200...
How to replace hv diode for gt4175sts microwave
you must !!!!!!!!!! discharge the capacitor first or it will kill you !!!!!!!!! use a discharge wand then cut out old diode and resolder new one ..
ps tell me why are you replacing the power diode in 15 yrs working with microwaves ibe never seen one blow
Dec 02, 2010 | Whirlpool GT4175SPS Stainless Steel 1200...
Microwave GT4175SPS 3 runs but won't heat
Most likely causes are a blown fuse in HV area of microwave or an open thermal protector or thermal fuse.
Less likely causes are failure of various parts in the HV area.
Due to the lethal dangers inherent in microwaves, servicing of these parts is likely best left to a professional. That said, if you are technically versed I can point you in the direction of some good resources for troubleshooting and repair.
Oct 21, 2010 | Whirlpool GT4175SPS Stainless Steel 1200...
Whirlpool gold GT4175SPS-2 inside door paint is flaking and revealing metal. Is it safe to use?
Scratches, flaking and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord first.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 09, 2010 | Microwave Ovens
Whirlpool gold microwave gt4175sps - problem: will
Apr 18, 2010 | Whirlpool GT4175SPS Stainless Steel 1200...
Is there a replacement microwave for thermador MBBS that fits MT30S trim kit?
Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
Dec 20, 2009 | Thermador MBBS Microwave Oven
Turntable not turning
On this brand it has a turn motor and the motor is bad or the fuse is bad, here is the page for you to llok at it to see if yo wantto tackle it or not fuse is in secton 3 or 4, here is the web page.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132508&diagram_id=936735#d936735
Hope this helps.
Dec 13, 2009 | Whirlpool GT4175SPS Stainless Steel 1200...
How do you install a built in whirlpool microwave oven
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc.
Nov 23, 2009 | Whirlpool GT4175SPS Stainless Steel 1200...
Nov 21, 2008 | GE JE1640 Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
