Question about Kenmore Refrigerators
How to tighten handle on door of kenmore ultra fresh
Posted by Bobby hawkins on
  • Kenmore Master
  • 6,220 Answers
There are two handle styles for the Kenmore Ultra Fresh refrigerators available around the time of the model, 106.55539400. On one handle style, you need to remove trim pieces to access the part of the handle where it is attached to the door of the refrigerator. In turn, apply firm pressure on each trim piece and push it away from the handle. (Push the top trim piece up and the bottom one down.) For the other style, the handle locks into shoulder pieces that are attached to the door. Again use firm pressure on the handle; hold it in the middle of the handle. Push the handle up until it clears these shoulders. Then determine the correct screwdriver tip to use to tighten these screws. See page 7 of the manual, https://www.searspartsdirect.com/manual/25o0qstrl6-000582/kenmore-10655539400-side-by-side-refrigerator , for pictures of these handles. On some more recent refrigerators, you will need to use an Allan wrench to tighten set screws to the hardware shoulders on the door. There will be a small opening on either end of the handle for the Allen wrench to be pushed into contact with the screw.
Please add a comment with the model of your refrigerator for specifics about the handle for your unit. I hope this helps.
Posted on Nov 02, 2019
5 Related Answers
Anonymous
SOURCE: loose handle on door
for GE profile french-door freezer door, pull right...
Posted on Oct 19, 2008
Anonymous
SOURCE: bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Posted on Jan 19, 2009
SOURCE: door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Posted on Feb 13, 2009
Anonymous
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Posted on May 29, 2009
BIKER T
Terence Fourie
  • 909 Answers
SOURCE: My Kenmore Coldspot side by side door handle is
Normally on the handle is a cosmetic cover. Use a small flat screwdriver and pry it loose. underneath are the 2 screws you are looking for.
Posted on Oct 23, 2009
Kenmore Side by side fridge/freezer Model; Jsi 23. How do you tighten handle? I see no removable screw hole covers and nothing visible behind seal inside door.
Try pushing in on door handle & pushing up simultaeneously. If handle comes off there may be srews holding the clips.
Apr 18, 2018 | Kenmore Refrigerators
How do you remove the handle to get to the screws to tighten the handle its very loose
Hello Martin;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on the upper inside wall of your fresh food section. So, I can not be accurate in regards to your unit.
1.) Inspect your handles. Are there 3/32" allen wrench screws at the top and bottom? If so back off the screws until the handle comes off. Then tighten the screw on the refrigerator door. Put handle back on the and tighten the 3/32" screws.
2.) No external screws - Then the handles are held on in a slip in slot fashion. Pull up on the door handle. This is going to take a little mussel. Remove the door handle. Tighten the screws on the door and the back of the handle. Slide handle back into place.
Mar 25, 2015 | Refrigerators
How does someone tighten the handle it is very loose
go to www.youtube.com
refrigerator door handles out loose
see if anyone has idea on how to fix it
most of the time is the way people word there questions or answers to get the right help
manufactures name, make or model #, handle are loose
how to fix
www.howto.com/manufactures_name/model#/service_manual
/ door_handle_diagrams
www.wikipedia.org/manuf./model#/doorhandlediagram
Elite range
This pertains to model 790 Kenmore ranges, comprised of an oven door handle that is mounted on the door's glass.
Be careful when tightening the oven's door handle. Even slightly over tightening would likely result in the glass shuttering, because tightening the screws pulls in and thus presses the handle against the glass. This is a problematic design in my opinion. I'd rather give up on a couple inches in the width of the glass, than be unable to adequately tighten the screws fastening the handle and risk shattering the glass.
Aug 24, 2013 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Door handle is coming off. how do i tighten it up?
Hello, Thank You for using FixYa. I will be helping you today. The freezer handles are a pain to tighten. The handle slides sideways and locks onto clips to remove you have to slide a card like a credit card under the base of the handle to release the tab and slide it sideways. When you get it off tighten the screws and you can bend the clip so it stays tight.The fresh food door is just the side screws
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Amana ABB192ZDEW Bottom Freezer...
Handle is loose on refrigerator,how to tighten the handle
There should be some small Allen (Hex) screws on each bottom side of the handle. Just use a Allen wrench and tighten it up.
Jun 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore refidgerator with loose door handle
usually there door tightening screws at the top edge and bottom of most frig doors there will be plastic caps covering the screws..
Nov 14, 2009 | Washing Machines
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Door handle is loose
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
142 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
