No spin,orlitespintry these:bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to checkUsing a multi meter check for continuity the door switch, which when bad may not allow agitation or spin.Bare in mindthelid switchassembly can fail either mechanically or electrically.
Check the clutch,motor coupler, brake assembly,transmission,and mode shifter or actuator. one way to check for slipping is to get under the machine after a spin cycle ( this is if u get alilspin but not much leaving clothes still wet) mix in a spray bottle alilwater and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to thetranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and useurhand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professionalappliantologistswill do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub andtrannyto the motor. ( if its bad u usually get no wash or spin or very little of either)
Nextif belt drivencheck for a loose, worn or broken belt.And on some models there is no clutch but rather what is called asplutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a pluggedwaterpumphose or obstructed water pump propeller. Check these by eye and hand.And in some models check with a meter for continuity and voltage.
LID SWITCH TEST-next step is toremove the cabinetand jumper thelid switchharness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in thegearcase- look for trouble in theclutch,basket driveor thetub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to thegearcaseby a drive coupler; that's why it's called adirect drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is freecuzGod is good!
SOURCE: ps2 spinner wont spin
hi..this is jagdish ...i fix all ps2 problems...there can be 3 problems
1-you have a lens failure
2-if your ps2 is modified then the chip can have a problem
3-or the mechanism on which the lens moves has failed
[email protected] byeeeeeee
SOURCE: top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
SOURCE: the spinner wont spin
clog, take bottom apart and clean, keep cleaning it theres more in there
SOURCE: spinner will not spin
have kenmore 70 series washer model: 110.7015626w that will agitate but sluggishly and will not spin but the belt is getting hot (drum is not spinning but the motor is running).
SOURCE: Kenmore Elite ultra wash DW model 665
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
