Can't find model number on Dynamic-Glo wall heater
Posted by Patrick mccracken on
Kenneth Simmons
  • 1,139 Answers
Do you see the tag like in the manual below and across from series is the model. under specifications
Hope this helps
https://www.ghpgroupinc.com/manuals/Wall%20Heater/Wall%20Heater%20Manual%202018_IR30NMDG-1.pdf
Posted on Oct 07, 2020
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: glo warm wall heater will not stay lit
Hi Cindy,
It seems that your heater is not sensing the flame is lit and is shutting gas supply off. There should be what is called a flame sensor, it is a thin pc. of metal that sticks out into where the flame when lit.
This usually gets charred and dirty, if you unscrew it and clean it with a soft cloth then re-insert it, it will get you by. You should get a new sensor when you have a chance.
Good luck and be sure to disconnect from any power source or turn unit completely off when orking on it.
Thanks,
Paul
Posted on Jan 28, 2009
Anonymous
SOURCE: Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Posted on Feb 24, 2009
Anonymous
  • 4 Answers
SOURCE: I have a blue flame GLO WARM 20btu wall model # WMP20A
Look for and clean the flame sensor.
Posted on Dec 06, 2009
Anonymous
SOURCE: Have Dyna-Glo Unvented Gas-Fired Room Heater,
I had the same issue. Iwent to the local harware store and bought heay duty mirror hangers. They work great for only a few bucks.
Posted on Dec 09, 2009
Anonymous
  • 39 Answers
SOURCE: I have a Dyna-Glo vent-less wall mounted natural gas heater
If it is a few years old, it could be the thermocouple. These are usually available from Lowes. Take your model/serial # and if you can, take the old part too.
Posted on Dec 11, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Where do i find a blower for my 30000 btu glo-warm heater
You will need the model number for your heater but you can find them on desaparts.com
Sep 29, 2010 | Desa International Blower Glow Warm Wall...
We currently have a Dyna Glo wall heater in our "garden room" and want to buy another for a 2nd home (will go in garage). Our model number is RMC-50NGT. Where can I buy??
Hmmm ... where did you buy the last one? Are they out of business?
Here is what I found when I used Google:
http://www.mytoolsbee.com/cat164509.html
Ace Hardware may be a place you can order this stove from also.
Thanks for your question at FixYa.com
Feb 16, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
I am needing to to buy a thermal coupler for a dyna glo wall mount heater model #RMC50NGT where do I find one???
Almost any hardware store carries thermocouples and thermopiles. Take your old one with you so you get the right length.
Jan 28, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
I have a Dyna-Glo vent-less wall mounted natural gas heater model number RMI-60NG Pilot light ignites.However no gas will supply too the burners.Causing them to be inoperable.What might be the cause of...
Dec 11, 2009 | Dyna-Glo Heating & Cooling
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
A blower you can hook up to the dyna-glo wall mount heater
only if there is one for the particular model heater you have ck with dealer in your area
Nov 24, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
