MY TRIO IS NOT WORKING WITH MY PEDAL - Audio Players & Recorders
Posted by Jerry Moreau on
Mustang will not start, unless you pop the clutch, put in a brand new starter and it still will not start on its own, battery is good, all lights in car work and so does the power windows.
There are several systems which control the starter. Stick-shifts may have a starter cut-out switch on the clutch lever. Automatics have a cut-out switch on the brake pedal lever. These switches are easily hit by the drivers feet and rendered inoperative. Check your brakelights if this is an automatic.
The idea when these systems were designed is to prevent the car from starting in gear or to lurch. It was thought that requiring your foot to be on the brake pedal or requiring the clutch to be pressed in would disengage the drivetrain or prevent lurching.
The alignment of shift linkage can also affect the switches. Usually this is arranged in a trio: brakeswitch, shift lever, and ignition switch or clutchswitch, shift lever, ignition switch. The manufacturers simply want you to have the car in Park or Neutral, clutch depressed, and foot on the brake before turning the ignition to start.
You may also need to check the small wires on the starter relay to see if a signal from the trio is getting through. That is what the trio is designed to control.
Sep 01, 2015 | 2001 Ford Mustang V6
The Digitech Trio seems to be frozen, when I start it the red light blinks slow, after pressing the pedal it starts to blink fast but will do nothing after that
This is almost always due to the guitar signal not getting to the TRIO guitar input. The fast blinking LED should go solid red on the first strum. Make sure your guitar volume is turned up and that if you have a volume pedal or tuner or any other effect between the TRIO and the guitar, that it is passing the signal.
Aug 22, 2015 | Music
Trio Stealth G2 HYpe tablet will not connect to wifi. Had been working but now can't get the wifi to turn on.
I had intermittent trouble with connecting my Trio Stealth Pro 7" tablet to my secure wireless. I have since upgraded my DSL modem / Bridge and have not had an issue since. You should contact your service provider if you have had the same equipment for a number of years.
May 28, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Trio tablet screen stuck on trio logo
hi try doing it this way.all data will be lost...
Jul 07, 2017 | Tablets & eReaders
How to restart a trio stealth G2
all that shows is trio stealth G2 when turned on it freezes I tried the reset button
Jan 07, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
My Trio Stealth Pro 7 in. Internet Tablet will not connect to my wi-fi.
I HAVE AN TRIO STELTH PRO.I AM ON RR INTERNET.I CANNOT CONNECT TO INTERNET NOR WI-FI AT HOME BUT I CAN TAKE IT TO MY DAUGHTERS & IT WORKS FINE.ALSO MY LAO TOP WORKS OK ON MY WI-FI.IT IS BLOWING MY MIND.THANKS TROY PRUITT
Jan 30, 2013 | Mach Speed Trio 4GB 7" Trio Stealth Pro
How do i reset my trio tch843? My trio is frozen and touch screen will not respond.
i have had same thing happen to me. I fixed it by chucking a brick at mine. Worked for me! ;)
Apr 27, 2010 | Mach Speed Trio TCH843 MP3 Player
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
