Question about Hunter Dryers
I have a hunter celling fan #99122.and my remote is not working plus a blue light is on on the remote
Posted by Burnell Hills on
5 Related Answers
Anonymous
SOURCE: ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Posted on Nov 25, 2007
masterof o
  • 4 Answers
SOURCE: i installed hunter fan yesterday
make sure the dip switches are matching with the receiver and the remote control,
Posted on Mar 31, 2009
SOURCE: hunter fan remote 85095-02, red signal light glowing continualy
It's continually transmitting. My guess is there is a button stuck causing the unit to run down batteries. If no button stuck, you'll probably have to replace the remote -- it's a fulty transistor.
Charlie
Posted on Aug 25, 2009
Anonymous
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Anonymous
SOURCE: Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Posted on Mar 11, 2010
I have. Hunter model 99122. How do you reverse the fan direction with the remote
If you have this kind, it is actually INSIDE the lighting housing. Remove the glass dome, and there is a little slide switch next to one of the bulbs. Such a bad design, but, yeah . . . .
Apr 05, 2018 | Hunter Dryers
I have two hunter fans mod no: 99122 that are connected to the same remote. Sometimes the remote turns them both on and sometimes it only turns one on. What do I need to do to fix this?
Put them both on separate frequencies. You really shouldn't put two fans on one remote or you encounter the problem you have.
Sep 04, 2015 | Hunter Dryers
How can I change the battery of a remote control model # 99122?
I had the same problem and finally determined there is a small plastic tab on the underside of the cover opposite the screw. That tab is in the center edge of the cover. After removing the screw, hold the remote with the screw side up, then use your thumb to press down in the center of the cover on edge seam where the cover meets the remote body. While pressing down you will be able slide the cover off the end of the remote to expose the CR2032 disc battery. Replacing the cover by sliding it on is much easier than removing it. Hope this helps.
Jun 24, 2014 | Hunter Ceiling Fan Light Remote Control
Hunter fan remote control 99600 not working
This must be a common problem, since I Googled the part number and it popped up before I completed the number. I am going to have to order a new remote, since I don't have a solder pen. Wish me luck.
Jun 22, 2012 | Hunter Dryers
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Feb 28, 2011 | Vacuums
I have a Hunter Ceiling Fan Model # 23529. The remote control works for the fan but not the light; ;I believe I need to replace the Remote Control Receiver 85112-04-000. Can you please tell me where I...
The receiver part #8511204000 and runs like $50 plus shipping....if its the remote the replacement part# 23529-300 and it runs like $40 plus shipping. You can order it from Hunter or other Hunter dealers.
Aug 26, 2010 | Hunter Ceiling Fan Light Remote Control
Remote will work the fan but will not work the light
sounds like the power supply at the ceiling (normally a blue wire) has come loose, also check the bottom of the fan where the light fixture connects, for loose blue wire. if thats not it ,it may be a bad remote control, (but probally not the remote. ted
Oct 15, 2009 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
243 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
