Question about Craftsman Garden
I would like to have instructions on how to rewind the nylon string on my spool of my craftsman weed wacker. I lost the instructions.
It is a model 316-7943 craftsman weed wacker.
Posted by Clifford K Honjiyo on
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
Aug 04, 2015 | Cars & Trucks
I am trying to change the string on a Craftsman Weed Trimmer
Usually you "Push in" as you turn them. Or...there is a knob with a male thread shaft screwed into place holding it all tight. Hold the spool steady as you try to turn the knob off. Or...there is simply a "nut" to take off. But for the most part the newer wacker spools usually just "push in and turn/twist" out. Simple. to reinstall it or replace it with a new one simply push and twist it the opposite removal direction. FYI most lines can be manually "rewound/refilled" by yourself and reused over and over until they really wear out. There are little tricks to doing a rewinding but it isn't anywhere near difficult to do...or learn. Usually the price of a replacement spool is 5 times the cost of rewinding them yourself. Comon its easy! If ya want I'll help ya thru it.
May 10, 2010 | Craftsman Garden
How do you get the spool off of a gas (31cc) ryobi weed wacker? The string is stuck up in the spool and I can't get it out.
The knob on the bottom unscrews, and the spool comes apart once you get that off.
Mar 27, 2010 | Garden
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Wind string on Spool
Most weedeaters have an arrow on the spool. Look at both ends, you'll probably find the arrow. Put your line into the hole and wind the line in the direction of the arrow until you have enough loaded.
Sep 04, 2009 | Garden
String stays out
You probably have to replace the rewind spring. If you are not familiar with how to do it, I would take it to a shop for repairs. If you have had your trimmer apart, then you know where things are. If you want to do it yourself, get back to me and I'll try to walk you through it. Good luck...Lee
Sep 04, 2009 | Craftsman Garden
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
LOST MY BOOK ON THE CORDLESS POWER GLIDE WEED EATER. i DON'T KNOW HOW TO CHANGE THE SPOOL.
attached is a scanned copy of the page of the booklet to change the spool; if this is not what you want, I also have scanned the page to show how to rewind the spool
Jun 12, 2009 | Ace Hardware Power Glide Cordless String...
Double spool on Weed Wacker
This isn't a solution to the problem. However, I think you should talk to someone at Home Depot or Lowes or wherever you bought the model, and see if the string is in there correctly; if it is, then u'r weed wacker must have some other mechanical problem. Sometimes it is just best to buy a new one. The more expensive models are the best.
Aug 10, 2008 | Electrical Supplies
Garden Logo
98 people viewed this question
Top Craftsman Garden Experts
Dennis Key
Dennis Key
john h
Sheldon Dedek
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
