SAM 4S NR 500 The till continually shows Warning Paper Feed Roll although there is no problem with it. The till will not operate while this is showing
5 Related Answers
Mac Gyver
  • 168 Answers
SOURCE: PAPER FEED
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Posted on Jan 28, 2008
agustin
  • 21 Answers
SOURCE: paper feed
If the print-out is an 'alien-like' one, the problem is on the sensor of the printer. The sensor is on the opposite side of the gears. Under the black cover.
Posted on Feb 16, 2008
Anonymous
  • 25 Answers
SOURCE: I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Posted on Sep 19, 2009
Anonymous
  • 19 Answers
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Posted on Dec 30, 2009
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
Brian Graney
  • 8 Answers
SOURCE: ink ribbon or paper roll error. the in ribbon is
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Posted on Jan 26, 2011
Sam4s cash register
sam 52xxm registers use two thermal printers....so make sure the paper is thermal and not in upside down. also make sure the receipt on/off function is "on" . and finally see if the tubular black paper feed roller hasn't popped out of its socket making the paper not turn or advance
Aug 30, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
The register keeps freezing and then shuts off. it says that the till roll is not properly inserted although it is
Hi Leanne
check around the path that the paper goes through, look for any dust build up or small scraps of paper and blow out/remove and try again. Hope this helps.
Feb 17, 2013 | Computers & Internet
My tec ma 1450 register won't work just blinks 0.00 and none of the keys work
With paper loaded properly, turn off/unplug register, turn MA or Service key to "Blind" position (approx. 5 o'clock), turn on/plug in register. "Status-C" will print on the receipt. Some of these TEC's won't reset after changing paper, and this procedure becomes necessary after each installation of a new roll of paper.
Jul 18, 2012 | Computers & Internet
My pictures are coming out with pink or purple streaks. Every time I print a picture, the streaks are in different places, all going from bottom left to top right . I have changed the ink roll and the...
Try cleaning the paint roller.
6 Care and maintenance
Cleaning the paper feed roller To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the paper feed roller clean. Inspect the roller weekly for debris particles, and clean if necessary.
IMPORTANT: Unplug the power before cleaning the paper feed roller.
spacer.gif spacer.gif spacer.gif spacer.gif 1.Unplug the AC power cord from the power outlet.
2.Remove the paper tray from the photo printer, and leave the paper tray door open.
3.Lightly moisten a lint-free cloth with water.
IMPORTANT: Do not use cotton or cotton swabs to clean the paper feed roller.
autourg00462006id1604162.jpg 4.Use the moistened cloth to gently wipe clean the surface of the paper feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
5.Allow the paper feed roller to fully dry before reconnecting the power.
Click below for the complete manual:
Kodak EasyShare Photo Printer 500 Manual
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Kodak EasyShare Photo Printer 500
Display H and do nothing and till left open . can not close the till
hmmmm are you try to install new paper roll?
the paper feed arm didnt lock
open printer cover and again install paper roll
and close the printer arm
then press cl key
Sep 26, 2010 | Sharp XE-A402 Electronic Cash Register
I'm getting an error code of W8102. Can anybody out there tell me what that means??
W8101/8102 - Print media position warning
The paper over the platen lies too near or too far from the carriage home position
when fed into the printer.
Cause>
The paper on the platen was too close to or too far from the carriage home position
side when paper was fed.
<Probable faulty component>
The way in which paper is set, print paper, cassette/cut-sheet feed unit, carriage
unit, encoder sensor unit, linear scale, carriage controller, head controller, system
controller.
<Action>
1. Paper setting check:
Reset the paper if the setting is not correct.
2. Paper check:
Replace the paper when any stains or pre-prints are found.
Straighten or replace the roll media when the roll of paper is ruffled.
3. Cassette unit/cut-sheet feed unit:
Replace the faulty paper feed component when the paper feeding is performed
correctly in all parts except where the error occurred.
4. Check the linear scale:
Visually check the linear scale for abnormal conditions, such as stains or damage.
5. Replace the carriage unit.
6. Replace the head controller.
7. Replace the system controller.
May 18, 2010 | Canon BJ-W9000 Copier
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
NI have a HP Design Jet 110plus nr after put the roll hi start to take the paper roll and take out the all roll witout control. Im chaged the OOPS sensor but is same problem can you help me to solve this...
Im chaged the OOPS sensor but is same problem can you help me to solve this problem
Oct 05, 2009 | HP Designjet 110plus nr InkJet Printer
Paper Jam
I have this problems whit Cleanout Assembly you need change it and problem solved cleanot assy have paper jam sensors and if sensor damaged you have problem whit paper jam !!
Aug 01, 2008 | HP Designjet 110plus nr InkJet Printer
52 people viewed this question
Ekse
Marvin
Marvin
