Question about Optics
My DSC GB200 Golf Buddy is off-2 yards compared to my buddies range finders. Is there a way to adjust?
Posted by Richard Jarrett on
  • Anonymous Nov 01, 2019
    If you are two yards away from God, you better watch out - apparently he's even worse than Santa Claus.
5 Related Answers
Mr Tech Geek
  • 133 Answers
SOURCE: Will not pick up the flag over 150 yards.
You need an alignment. The transmitter and receiver are not pointing at the same spot. The farther the distance the bigger the gap between the two. Dropping the rangefinder and vibration are killers to Pinseekers. Bushnell will fix ya.....
Posted on Apr 10, 2009
Anonymous
  • 3 Answers
SOURCE: MY NIKON 550 RANGE FINDER
Same problem. Conclusion: just because it has the NIKON name does not mean it is not a piece of Chinese junk.
Posted on Nov 09, 2010
taran_2005
taran_2005
  • 10515 Answers
SOURCE: my medalist range finder is
The unit needs an alignment. Vibration and dropping the unit is the number one killer of rangefinders.....After a while of using them, (bouncing around in golf carts, cup holders, dropping them on the cart path, or the ground) small prisms start to move inside and decrease the units effective range.... (only able to hit a target at about 150 yards or less) People that use these type of instruments have to realize that the laser beam is the straightest line in the history of man!!!. Alignment is crucial!!!
Alignment is due. For all you players that think its okay to take off the eyepiece cap.....(bad idea) This is why you see oily looking spots or black spots in the view. Direct sunlight will be magnified and burn the surface of the LCD. Bushnell is good about warranties but, if you take it apart...the warranty is void!!!! So if its 2 years old or less.....(send a copy of the proof of purchase) .send it to them. If you have sunlight burns already...this won't effect the performance of the unit. Wait till something else is wrong.
THE COST..... $50 for alignment, $15 for LCD, $40 for newer eyepiece that helps deflect direct sunlight (will not prevent thermal burns but, protects for longer periods of time before damage happens) $15 for clean and adjusting. Bushnell's# 800.423.3537
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 18, 2011
Anonymous
SOURCE: My Bushnell Medalists which is a year old is off
I got one for Christmas 2010. Also found that it is off by 10 yards compared to several other rangefinders/gps units.
Posted on May 15, 2011
phil_hick883
Phillip Hicks
  • 917 Answers
SOURCE: Battery replacement for golf buddy range finder
Ask on Internet , All cell types available , even advises you on different make & types, See if you can get old Battery out of Buddy Range Finder,
Posted on Mar 14, 2015
Change my golf buddy from metric to yards.
Hi John,here's a link on your golf buddy,it tells you how to change from yard to metric.Chapter 2,section 19.
Sep 28, 2016 | GolfBuddy Golf Buddy VOICE GPS
Where to get replacement battery for Golf Buddy Voice GPS
get the battery in your hand and type in the details in the search section of e-bay and the battery will show up
take the battery to a good battery shop and get one
Oct 11, 2015 | GolfBuddy Golf Buddy Voice Gps Range...
Mar 14, 2015 | GolfBuddy Golf Buddy - dsc-gb200 - Golf...
My lithium battery has died out. can I use conventional batteries, chargeable or non- chargeable ?????
Lithium batteries are the best for products that use a high amount of electricity. Examples are flash cameras and high intensity lights. They are also good for cold weather applications because they remain chemically active at low temps.
Golf buddy pro
Here is a site that carries replacement batteries for the golfbuddy pro gps range finder: Golfbuddy Pro GPS Battery
Sep 23, 2013 | GolfBuddy Golf Buddy Pro GPS Range Finder
Optics Logo
119 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
